Flag mount for 09 SG
https://www.hdforums.com/forum/touri...e-results.html
I looked at these also, but how do they mount to the bag?
The heart of the TCM mount is the cast aluminum base designed specifically for Touring Class Bikes.
Mounts to virtually any flat surface using 3M® VHB double-sided tape, which cures forming an acrylic bond to hold the mount in place.
Mounting base does not touch or mar the mounting surface. By design the 3M® tape fits inside a recessed area on the bottom of the mount and is thicker than the recess, so while the tape cannot be seen, it
supports the mount above the surface.
Two mounting angles include the TCM.22 and TCM.45, available in black satin or triple chrome plated.
The TCM.22 is designed for both vertical and horizontal
installation depending upon the location chosen.
The TCM.45 is specifically engineered for installation on
hard saddlebags or extreme trunk angles.
