Electrical problem
Old Jun 16, 2009 | 09:38 PM
2007rkjb's Avatar
2007rkjb
Default Electrical problem
Hi,
I'm leaving for Laconia TOMORROW and I need a quick fix for an electrical problem.
Tonight, my brake light got twice as bright as normal and started flashing while I was riding.
At the same time, my cruise control quit. Bike is a 2007 RKC.
Now I don't trust the bike to make the trip safely. I need to fix this before I can leave.
Any ideas ???
Thanks in advance,
Jake
Old Jun 16, 2009 | 09:44 PM
ranger56528's Avatar
ranger56528
?..Have you done anything with the handle bars,i.e put differant ones on,if so you might have a pinched wire....
Old Jun 16, 2009 | 09:50 PM
2007rkjb's Avatar
2007rkjb
Nope,
Haven't done anything.
Jake
Old Jun 16, 2009 | 10:11 PM
ranger56528
still check your wires in the right switch......
Old Jun 16, 2009 | 11:55 PM
hogbag07's Avatar
hogbag07
When the brake light gets power the cruise will disengage automatically so your problem lays with a brake light switch being unplugged or a short in the brake wiring somewhere between the front and rear brakes.
Old Jun 17, 2009 | 12:06 AM
jchill's Avatar
jchill
I don't know about an '07 but with the '05 that pesky brake switch is $75.00 (give or take) and it's a long wire attached and bare ends. No plug-in. You either get the metal covers/plugs, attach onto the end of the wires and then replace into the plugs behind the headlight. Oh and you will have to feed that wire thru your bars or the cable on the outside. Pain in the A***.
The quick fix is to tin wires and solder just inside of the housing. Tricky but works (experience).
All this takes time which doesn't sound like you have.
Old Jun 17, 2009 | 09:49 AM
chris4401's Avatar
chris4401
If nothing was done to/with the bars, check the rear brake light switch (right side, along the frame, just rear of the floorboard). Had one go bad with similar symptoms. Easy fix.
Chris
mn902
Electrical/Lighting/Alarm
Mar 14, 2015 04:35 PM
mfortkamp
Aug 28, 2014 02:23 AM
2007rkjb
Jan 30, 2012 08:39 PM
Ultradickweed
Oct 1, 2007 01:50 AM
Retired_Ted
May 6, 2006 08:16 PM
