Air suspension valve location
Old Jun 16, 2009 | 03:39 PM
bikehunter's Avatar
bikehunter
Default Air suspension valve location
I have just been for a ride this evening and the suspension bottomed out on a rut. Need to pump them up if only I could locate the valves, pipes go down and under the riders seat but cannot find where they end up. Any ideas?
Old Jun 16, 2009 | 03:51 PM
dawg's Avatar
dawg
Stock air shocks? Schrader valve should be behind left saddlebag lid. Use the HD air pump or the like, don't use a compressor
Old Jun 16, 2009 | 04:17 PM
Clint55's Avatar
Clint55
Also might want to check your owners manual for suggested pressure to weight ratios. Big difference between the 09's and earlier versions. I weigh in at 250 and my 09 manual calls for 50lbs on the air shocks. On my 08, I had it set at about 20 and it seemed right.
Old Jun 16, 2009 | 05:07 PM
cbears's Avatar
cbears
+1 on the manual. I won a bet with a buddy that has a 2007. He laughed at me when I told him I had 42 pounds in mine. Also +1 on the HD pump, don't pump them up without one. From what I hear they are easy to blow the seals in if you do it wrong.
Old Jun 16, 2009 | 05:08 PM
bikehunter's Avatar
bikehunter
Do you know, I have looked all around there but still can't see them, Will check again tomorrow, thanks!
Old Jun 16, 2009 | 05:15 PM
dawg's Avatar
dawg
It should have (if it got put back on) a chrome cap and looks just like a tire valve stem. It is attached to a bracket up behind the left saddlebag off of the fender strut
Old Jun 16, 2009 | 08:32 PM
Potato_Potato's Avatar
Potato_Potato
You might want to take the left saddlebag off - might be easer to see.
Old Jun 16, 2009 | 09:43 PM
bjpharmd's Avatar
bjpharmd
since the subject came up, i have an 09 Road King. I weigh about 190 and my ole lady weighs 100' ish. What should i be running at when we both ride. Ball park. We bottom out every once in a while.
Old Jun 16, 2009 | 10:51 PM
krussell's Avatar
krussell
40-50 psi. Probably closer to 50 if you are carrying anything.
Old Jun 16, 2009 | 11:07 PM
cruise_carter's Avatar
cruise_carter
Don't know what bike you have but on my 02 EGC, the valve is near the right saddlebag, not the left. Open the lid and its right there.
