GPS Fairing Mount
Old Jun 17, 2009 | 09:20 AM
btharris24's Avatar
btharris24
Default GPS Fairing Mount
Does anyone know if the Garmin Zumo 450 will work with the HD Fairing Mounting Kit?
Thanks
bh
Old Jun 17, 2009 | 09:57 AM
SGLarry's Avatar
SGLarry
I would tend to think so since the differences between it and the 550 are software features only. The outside casings are identical.
Larry
Old Jun 17, 2009 | 10:31 AM
hdbe's Avatar
hdbe
what is the hd fairing mount kit?
Old Jun 17, 2009 | 10:33 AM
btharris24's Avatar
btharris24
That's kinda what I was thinkin', my local HD shop doesn't have on in stock so I just wanted to double check before I ordered one, Thanks.
bh
Old Jun 17, 2009 | 12:23 PM
08UltraRider's Avatar
08UltraRider
I have the HD mount with a Zumo 550 where you use your existing M/C cradle with this mount. If your cradle is the same as the 550 (part #010-10859-00) then yes it will work.
Old Jun 17, 2009 | 01:42 PM
btharris24's Avatar
btharris24
The part number I got from my local guy was #92366-08, I'm hoping everything I need will be included to mount the GPS to the fairing.
bh
Old Jun 17, 2009 | 05:08 PM
08UltraRider
bh
That's the one I have mounted on my fairing. What came in the box for $55.00 Canadian was the mount, mounting hardware including gasket, template for drilling your fairing and the lousy HD instructions.
Like I said, you supply the cradle which I believe the 450 and 550 are one in the same. The part number I mentioned above is for the cradle from Garmin.
I like where it's mounted and can easily see the screen even in bright sunlight. Some vibration when idling but smooths out when the revs get up past 1500. The rubber cap is held out of the way at the bottom of the cradle with a built in magnet does block a small part of the view to the fuel gauge but not a big deal.
Old Jun 17, 2009 | 10:01 PM
BadPiggy's Avatar
BadPiggy
Does this HD fairing mount also work on RG's?
Anyone know?
Thanks!
Old Jun 18, 2009 | 08:48 PM
08UltraRider
Anyone know?
Thanks!
No... It only fits on the Batwing fairing.
92366-08
Fits '96-later Electra GlideŽ, Street GlideŽ and Tri Glide models. Does not fit with Road Tech™ XMŽ Satellite Radio P/N 76390-05A, '06-'09 CVO™ Electra GlideŽ models or models equipped with Fairing Dash Pad P/N 58628-05.
Old Jun 18, 2009 | 09:23 PM
Ridewva's Avatar
Ridewva
Thanks
bh
Works perfectly. Here it is w/o the Zumo 450, and with it.
