Major "Pucker Factor". I use to ride a lot in NYC. I lived in Queens. So sometimes I had to take the "Queenesboro Bridge to get in to the City. This is the bridge that is near the U.N, build. On the lowerr road the mid section turns to steel grid. If you are not ready for it ,it can be un nerving at best.If wet after a good rain even worse. So one day I think I'l try the upper level road... This was the worse I ever felt (Pucker Factor0 in my life. The whole span across the river was steel grid. I am sure I must have counted every steel stud on the bridge.
Yes, it is an experience to remember. Used to do it all the time when on the east coast. One tip, and I think it was mentioned above, is DON"T squeeze the grips. Kind of hold them a little loose, and let the bike track. It's amazing how it will just pick a path and follow it with little interference. Keep your speed up, but try it next time.
Crossed a multi-level steel bridge crossing over from Minn. into Prairie Du Chien Wisc. and it was at best a bit un-nerving!!! Have crossed several before but never 2 up and not one with mulitiple levels up and than down.
The next one was down at Old Shawneetown from So. Il going into Ky. It is a long steel bridge that arches and not on a flat straight across plane. Mid 8's on the pucker factor as well.
What happens is the front and rear tires track in slightly different slots. Gyroscopic stability forces the bike upright - this is what you're feeling - constant correction. Going slow provides less gyroscopic action/stability.
ev780, I was gonna say the same thing. Very similar feeling, a loose grip on the bars and letting the bike find it's groove seems to work the best for me. With all the repaving goin on in Illinois now, been getting lots of practice 18-20 miles at a time.
That's funny. My first couple of times were scary too.
Still don't like 'em though.
Heard a lot of stories about some bridge in Michigan that has about a mile of grate. Especialy freaky when it's raining.
Just checked. That bridge was mentioned earlier in the thread as the Mackinac which has 5 miles of grate in the center lanes to allow vertical upward air flow. Apparently the outer lanes were being resurfaced last year causing motorists to all have to use the grate which was nerve racking for motorcyclists.
