Today before work I did my pre-ride checks and my hi-beam headlight was not coming on? The blue light on dash lit up, but not at headlight. I had earlier washed bike. I gave it time to dry since I rode 30 miles to work today.
3 weeks ago I installed new handlebars, and noticed the main bulb itself was loose inside? Twisted it a bit to tighten and when all was back together it worked. I have washed bike numerous times since today when the problem started.
I was wondering if: A - The headlight needs replaced. B - Could it be a fuse. Or C - let it dry out more. It sucks that I'm at work and can't look at service manual. Anyone with same problem in past? My bike is 1 year old with 16,000 miles. I don't use hi-beam that often. Thanks.
Just another reason to run to Sears to purchase a continuity tester. ("Honey, I'll be right back...promise!")
