Holy Smoke - Help!!!
Old Jun 26, 2009 | 05:12 PM
albertasaurus's Avatar
albertasaurus
Did you do anything else with the bike besides the PCV, pipes, and A/C?
Old Jun 26, 2009 | 05:20 PM
absame's Avatar
absame
Nothing to the bike other than slip ons, PCV and A/C. Bike is only a week old --was running great. Bike smokes with or without PCV. Would a/c alone without remap or PCV cause it to smoke? If it would, at least i'll know it didnt screw anything up on the install and it's something with PCV.
May have wrong map - Fuelmoto sent it to me again, so I'll reinstall and update firmware. . How to you tell if PCV is working??
Old Jun 26, 2009 | 05:52 PM
Pops-A-Cop's Avatar
Pops-A-Cop
Again, I am no expert but I do have the Fuelmoto package and have no smoke. If the PCV is not installed, it would most likely run lean and smoke. Did you unplug the O2 sensors and plug in the little bypass thingies that came in the kit?
Old Jun 26, 2009 | 05:55 PM
QIKLUV's Avatar
QIKLUV
could it be sucking too much oil through the hollow bolts holding on the hiflo a/c assy?? then recycling it throught the motor???
Old Jun 26, 2009 | 06:11 PM
absame's Avatar
absame
I unplugged O2 sensors etc. Runs same with and without PCV.
Old Jun 26, 2009 | 06:12 PM
absame's Avatar
absame
Tech at Fuelmoto asked me that. How would I tell?
Old Jun 26, 2009 | 06:28 PM
Pops-A-Cop's Avatar
Pops-A-Cop
I wasn't aware that oil went through those bolts, only air I thought. You have the (3) little o0rings installed right? Don't mean to be asking dumb questions but you never know. Maybe try an pull the main fuse again and hook up the PCV again and reinstall the fuse????? Just to reset it.
Old Jun 26, 2009 | 06:37 PM
absame's Avatar
absame
Two original breather bolts were removed and replaced with 2 different bolts with o-rings. How would oil get in? How would I tell?
I'll update firmware, reinstall map, reset everything and try again, unless someone has another idea. So much for plug and play
Old Jun 26, 2009 | 06:38 PM
n8dc's Avatar
n8dc
oil in the packing on the mufflers .. ride it a while. It aint gonna blow up
Old Jun 26, 2009 | 06:42 PM
Pops-A-Cop's Avatar
Pops-A-Cop
I'd reinstall the stock muffs and see if it smokes before I'd ride it again. Hope you get it fixed soon, I feel your pain.
