Wobble
Old Jul 1, 2009 | 11:10 PM
Born2cure's Avatar
Born2cure
Default Wobble
Riding today taking a sweeping turn and felt the wobble then entering I 80 felt like the back tire was going out from under me. freaked me out brcause I have the bagger brace on thought the problem was solved. I checked the pressure 37 lbs. rims seem secure. still have plenty of tread even with 13000 miles on them. Anybody have an ideas at first I thought the wind might have caught the bike but then it happened again.
Thanks for any help
John
Old Jul 1, 2009 | 11:24 PM
HarleyWood's Avatar
HarleyWood
possibly steering head needs adjustment.
Old Jul 2, 2009 | 01:10 AM
gunner11's Avatar
gunner11
Mabye you should just slow down?
Old Jul 2, 2009 | 01:13 AM
emwolb's Avatar
emwolb
hey born to cure. are you running the stock dunlop 402's? i know that i'd get a serious butt wiggle when riding on rain grooves with that tire. i changed the rear only to the dunlop elite 3, and it's cured. no more butt wiggle. i left the front tire alone, because there is a lot of wear left in it. it surprised me that changing out only the rear tire would make that much difference. all i can say is, wow, what a huge difference. hope you get rid of the wobbles. yes, like the other poster mentioned, might be a neck bearing adjustment.
troy.j's Avatar
troy.j
I have had front end troubles (Rim once on my FLST and neck bearings once on my dads FLT) make it feel like the back of the bike is loose.
Old Jul 2, 2009 | 03:33 AM
sweet07's Avatar
sweet07
Does that bike have spokes? If so check 'em. 3/4 of mine were loose one time and I had that symptom. Good luck.
Joe from So Cal
Apr 11, 2018 10:18 PM
Redlegvzv
Oct 12, 2015 10:15 AM
mongomark
May 3, 2010 02:17 AM
Cohiba_Joe
May 29, 2007 09:37 AM
Edelmon
Mar 13, 2007 11:05 AM
