Three Different Compartments
Old Jul 6, 2009 | 12:08 PM
DGlide04's Avatar
DGlide04
Your car/truck has 3 different lubricants, no one questions that. Oil, Transmission fluid and rear differential grease all serve separate purposes and have to be formulated for the load they are subjected to. Motor oil is pretty light weight compared to the transmission lube most of us use. HD use to tell you to use Syn 3 in all 3 holes, some use Amsoil or another synthetic in all 3, it all depends on what you're comfortable with.
Old Jul 6, 2009 | 12:10 PM
Arizona's Avatar
Arizona
Originally Posted by kman780
Yea I agree with the practical theory... Also, sharing oil is not always a good thing. My dirt bike is "street legal" and the tranny shares the engine oil... Its not the best because the tranny really hammers the oil and its shot after 500 - 1000 miles.
On a cruiser having the ability to put 20w50 in the motor, 75W140 in the tranny and whatever else in the primary is best since not too many people leave their HD stock with the 88 or now with the 96 motors....
I'd have to agree with this. I don't know that sharing the oil with motor and tranny is the greatest idea. The tranny/clutch material gets into the oil and in my opinion that can't be the most ideal situation.
I think H-D has a good idea to keep them all separate and you can tailor the oil to the more specific application for each component.
Old Jul 6, 2009 | 12:19 PM
Jinks's Avatar
Jinks
Iclick's answer is the best so far. Metric bikes & the number of personal choices in lubrication show that as long as you use a reasonably decent lubricant these machines will perform well. There is no magic/perfect lubricant.
Multi-weight oil works well for easy starting & good viscosity when hot. Take a look at your 50W oil after an hour at 70/80 mph. on a 90+ degree day. It looks like water! So a good multi-grade for the motor is a good idea.
The gear box is where the power is forced to change direction & speed depending on what gear you're in. There's some pretty impressive shear factors involved, but it's pretty much a closed environment so filtering isn't a problem. Heavier weights handle the loads without having to be thinned for starting.
The primary is a totally enclosed environment with little heat or contaminant problem. You could probably use cooking oil in there. All you're doin' is lubricating a chain & givin' a wet clutch some slip when disengaged. I've always thrown a little over a quart of Castrol 20W50 in there. It's good oil & it doesn't cost much. It also works fine in the motor if you don't want to use synthetic.
Bottom line is that you don't *have* to use 3 different oils, but you can tailor your lubricants to best fit the job requirements while controlling your costs.
Old Jul 6, 2009 | 01:40 PM
iceman5218's Avatar
iceman5218
Don't disagree with ya on this one but the tranny and rear lube is done at 10k's of miles not every 5k.
The real basis behind me asking is the cost of a fluid change. When I would change fluids before on the schedule I was suppose to the fluids would cost about $30-$40 depending on brand and type (10w oil is usually a little cheaper than 20w). Now I know I bought a Harley and there are costs to owning one so that is not the issue. I just hate being taken advantage of . Having to buy $60-$80 in fluids every 5k miles seems a bit much to me. From what I've seen already the MoCo already has other things in place that make you come to the dealer more often to begin with and this seems to be another one.
Other companies don't require this and their bikes run for 100k's too.
I love my bike and am enjoying the Harley family (you guys really have blown my expectations out of the water). I just like to know the whys of everything. I was that guy in class that kept asking questions when we could have left if I would shut up, so sorry.
So to recap we have learned that the tranny has to be the strongest, then motor, then use the bacon grease for the primary. Do I have it about right. Can someone clue me in on how much of each. Don't have my manuals with me.
Old Jul 6, 2009 | 01:50 PM
shortride's Avatar
shortride
I would bet one of the reasons why those changes are not incorporated in all of the Harley's could be that it leaves Harley Davidson something else to do to future models to add improvements. I would bet that Harley will in the future, use the same technology as the liquid cooled V-Rod engine in other models. I would not have a problem with that.
Old Jul 6, 2009 | 02:18 PM
riteway's Avatar
riteway
Rutt-Roooe.You had us till you threw in the FACT that you don't have your manuals handy....... Now what are we to believe.Next thing is you will tell us is your SEARCH Button wont work!!!!!....Class is over LETS RIDE!!!!!
Old Jul 6, 2009 | 02:46 PM
jamesw's Avatar
jamesw
Correct me if I am mistaken, but didn't the Shovelhead share the engine oil with the primary at one time?
Old Jul 6, 2009 | 03:09 PM
07SG's Avatar
07SG
Iceman,
Currently the fluid change intervals are 5k motor oil, 10k primary, and 20k trans.
Old Jul 6, 2009 | 03:35 PM
Unome's Avatar
Unome
It just wouldn't be a Harley without the shake. So what about the different compartments?
Uuuhhh....my wife kinda likes the shaking of the bike.
Old Jul 6, 2009 | 03:45 PM
CW4_131A's Avatar
CW4_131A
Unome - my wife says the same thing all the time. Just before she says, "I want the bike to out last you so take good care of him". "Don't you mean her", I ask? To which she replies, with all the sincerity she can muster, "whatever...".
Ain't life grand...
