I need to know how hard it is to replace the front rubber bulge ,the front engine mount located under the oil filter area? Looks like it would be basic but , need to check just in case there are any hidden actions or special tools to perform. The rubber has a couple of cracks in it,and I don't know what this does to the performance of the bike.
Undo the bolt and use a jack to jack the engine up so you can remove the motor mount and install a new one. Just make sure you put it in right side up. They changed the design so it can be confusing (see attached).
Kennyjohn - I have a 00EGC and have changed 2 of them over the years, it's like dawg said simple just follow the constructions and TQ values. Good luck.
