Help!
Old Apr 1, 2015 | 04:17 PM
hogdog76's Avatar
hogdog76
4th Gear
Default Help!
I have a 2000 Electra Glide Classic I have noticed that on cold starts it's discharging trany oil. Any suggestions would be appreciated. Thanks
Old Apr 1, 2015 | 04:30 PM
dyna rider's Avatar
dyna rider
Default Tranny Oil
So have you checked the level on the dipstick ?
Old Apr 1, 2015 | 05:50 PM
J929626's Avatar
J929626
Discharging it from where?
Old Apr 1, 2015 | 06:08 PM
decencyxdefied's Avatar
decencyxdefied
I guess we can assume the variable = x. We can't solve for x without the rest of the equation
Old Apr 1, 2015 | 07:27 PM
hogdog76's Avatar
hogdog76
4th Gear
Not sure from where just noticed the last few times I started it there is a big puddle of oil smelled it and it smells like tranny oil there's no dip stick to check the tranny oil just thought this could be a easy diagnosed problem I will have to check it out better
Old Apr 1, 2015 | 07:32 PM
mkguitar's Avatar
mkguitar
the tranny filler is the one that uses an allen key to remove...it has a dipstick attached to it.
it is on the rt side of the bike just in front of the oil filler
the primary is on teh left side of the bike and has no dipstick but a visual check is used for levels on all the fluid levels- there are no absolute specs.
so we wonder if you are correct about which fluid is leaking...and if any of the fluids may be overfull
mike
Old Apr 1, 2015 | 07:46 PM
hogdog76's Avatar
hogdog76
4th Gear
Ok I know where the tranny fill plug is but trust me there is no dip stick. bike never did this until it got cold out last year put it away never really thought about it any more and now its doing it again so the primary is closed correct? so how could it come out of there? Is the tranny vented? if so why would it come out of the tranny unless it was overfilled? So if the Tranny was overfilled wouldn't it do it after it had been filled?
Old Apr 1, 2015 | 07:49 PM
hogdog76's Avatar
hogdog76
4th Gear
Hey Mike you can defiantly smell that it is tranny oil levels where fine it started doing it when it got cold out
Hayes Brashears
EVO
Aug 7, 2018 03:48 AM
Daddieo1
Jul 15, 2018 03:54 PM
lowperformance2
Apr 8, 2017 11:50 PM
kennyjohn
May 21, 2012 08:24 PM
az232
Nov 27, 2006 11:11 PM
