stereo help
Old Jul 7, 2009 | 12:19 PM
woppe's Avatar
woppe
Stage I
Default stereo help
I have a 2001 ultra there is no manual with the stereo does anyone know how to adjust the senstivity of the speed to volume control???????
Old Jul 7, 2009 | 12:42 PM
Scubamike's Avatar
Scubamike
I have an 09 SG but I believe the radios work the same. If you turn the radio on and push the Audio button on the left handle bar in, it will give you selections like Bass?Treble and such. On my radio button if you push the audio button in 5 times it puts you on the AVC selection which is Audio Volume Control and then you can adjust the audio switch up/down to desired settings. I believe I have mine set on three bars and that appears to work pretty good. Then to get out and back the the main screen just push the audio button in again. I know the radios have changed a little bit over the years but think they still function the same way as current. Good Luck and hope that helps.
Old Jul 7, 2009 | 12:46 PM
dawg's Avatar
dawg
See attached
TOFTS
2014-2024 Touring Models
Jul 28, 2016 01:17 PM
Bosko
Aug 27, 2012 06:23 PM
jimd3246
Jul 31, 2011 05:54 PM
codedawg
May 13, 2011 07:45 AM
VandalENG
Nov 12, 2010 07:25 AM
