Okay i forgot... i searched...... so leaving on trip....... all the sudden volume works but cannot change tracks it goes to FM so pissed i fixed this once but i have CRS any help appreciated
to clarify i hit handle bar thumb control right volume up left its down hit it up and we goto FM radio used to change tracks on usb or phone,,,
Up down is volume side to side change track.
Need to set infotainment to shuffle and seek.
Go to home > Media > Menu.
You will see seek scan track list repeat shuffle.
That's about all I can think of... Hope that helps ya...
PLAY PREVIOUS/NEXT MEDIA FILE (OR PREVIOUS/NEXT PRESET) Depending on the configuration, the PREVIOUS/NEXT hand control switch will either advance through each song individually, or through each preset that is programmed for the device. 1. Select Home > Media > Menu.
2. Press the multiselect button to show Seek (to advance through each song) or Preset (to advance through each preset). 3. Press the PREVIOUS/NEXT hand control switch to advance to the previous or next song (or preset) in the device.
the minute i read this my brain fart fixed itself i knew this and forgot
