Issue with my radio setup
Old Dec 31, 2013 | 10:21 AM
steveh326's Avatar
steveh326
Default Issue with my radio setup
Need some ideas if anyone has any...
Running a Sony marine media radio and a Hawg Wired adapter. Worked perfectly for a couple years, but now I am having an issue with the hand controls.
hand controls sometimes don't work, sometimes work intermittently, and sometimes they have a mind of their own, like if I bump the volume up a notch it runs all the way to max by itself.
I am just trying to figure out how I can tell if I have a radio issue (this radio is about a year old), or a hand control switch issue, or something else. I thought about looking for a used left side hand control and swapping it out, but I'm trying to avoid spending $$ on parts I don't need if there is some way for me to check it otherwise.
thanks for any ideas.
Old Dec 31, 2013 | 07:39 PM
z71_fourwheelin's Avatar
z71_fourwheelin
I would think the interface is what is going bad. It runs off a variant signal and if it misinterprets then it can do crazy things.
Old Jan 1, 2014 | 06:29 AM
steveh326's Avatar
steveh326
thanks, I wondered about that also but forgot to include it. my main issue is I have no idea where to start, I guess I'll start with the cheapest part and work up to the most expensive... I did talk to a stereo installer at daytona biketoberfest and he said he uses nothing but Hawgwired and has never seen a failure, but with my luck I'd be the 1st in history...
Old Jan 1, 2014 | 12:14 PM
z71_fourwheelin
I have a Hawg wired unit and mine was acting up the other day. Out of control volume up n down. No issue since.
Old Jan 2, 2014 | 01:29 PM
UltraNutZ's Avatar
UltraNutZ
go the biketronics controller itself and disconnect it completely. let it sit for a minute and plug it back in. If it's easier to access the fuse panel, just pull the main fuse out for minute and then plug it back in.
ncbeast
Aug 4, 2021 04:52 AM
SVBLUE
Audio Systems
Jul 18, 2017 01:49 PM
hdnvn
Apr 24, 2014 11:52 PM
Billsfirst
EVO
May 6, 2013 07:18 PM
Freedom 1
Apr 27, 2012 03:47 PM
