I am getting a pulse in my front brakes. It is very noticable at close to stoping speeds. Very nerve wracking. Either the roters are warped or there is something wrong with the pads. The bike is an 07 Street Glide and has 10,000 kms (6,000 miles). I wouldn't think there should be anything wrong with this kind of mileage. Can anyone help or do you have suggestions. Of course the warranty has expired; so, I don't think I will get anything from the dealer.
Does this happen all the time?
When going slow and 'lightly' using the brakes, can you feel it?
Both of these point to a either a clogged caliper (one side is trying to do all the braking) or a warped rotor. First (cause its cheapest), get a can of "Brake Kleen" and spray the brake calipars for 15 seconds behind (caliper side) of eash brake shoe. If that helps, you need to disassemble the calipers and clean them. If it does not help, you only wasted $6.
If it does not help, chances are its a warped rotor. That is, the rotor got too hot and has litterally warped. Don't try and 'see' teh warpage, if you can see it, have the bike towed to the shop or put new rotors on before you ride it again.
Do you have wire spoke wheels?
Loose spokes can have really strange effects when braking. A simple check for loose spokes if to take a screwdriver and 'tap' each spoke. You should get a simular 'ring' from each spoke. Those that are 'dead' or very different sounding are not right and you need to true the wheel.
Does the rotor have uneven wear? Replace the rotor.
NOTE: Anytime you replace the rotor, replace the pads and clean the calipers.
had the same thing once... warped rotor was the cause.
Was not noticeable until the bike was very close to stopping and made a smooth stop all but impossible.
Just as an fyi I would assume that this will be a warranty job for you, but the price dif for floating rotors is not too much. They look way cool, and provide better performance.
Have the front bike lifted to where you can turn the wheel by hand...take a metal object like a knife, wire, screwdriver etcc....brace it against the fork and turn the wheel, get the metal object as close to the rotor as possible see if it toches or not as you are turning the wheel...Cheap true gauge.....
Have you had it in for front tire replacement? Sometime if the tech is not careful he can mess up the rotor on the tire changing machine.
You have one or both rotors warped. Both rotors should be checked by dial caliper to determine warpage. The calipers should be taken apart when you replace the rotors to make sure the pistons are free to move and check for binding.
Sorry to be the last one to give his opinion but its more likely the rotors as I have had this on other machines when the rotor has distorted possibly through over heating and then pulsates when braking. More noticable when coming to a stop.
