TBW Issue "Again"
Old Jul 16, 2009 | 05:49 PM
rocknrod's Avatar
rocknrod
Originally Posted by JKs Ultra Classic
I hate to differ with those who indicate my first issue was not a TWB issue... ...if they moved the throttle. Issue corrected with a new software update.
I am not faulting the TBW, I just had two issue related to the TBW system.
Sounds like operator error.
And a "related", in your words - error.
Still my TBW (and yours) will get you home. Where a broken cable will not.
Old Jul 16, 2009 | 07:12 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
why not under warrenty its a 08 ?
Old Jul 16, 2009 | 07:56 PM
Dionicio's Avatar
Dionicio
17.5k on My 08 Ultra and I did'nt know I had TBW issues. I will get to the stealer right away, and have them fix it. They will probably tell me is operating normally.
Old Jul 16, 2009 | 09:18 PM
valleybuck's Avatar
valleybuck
My 08 Roadglide is at the shop now for the same problem.Yesterday they call and tell me its the throtle grip sensor thats what the code showed.I pick it up less than 2 miles it does the same thing.I take it back,the tech calls me today says its my V&H fuel pac,he disconnected it rode the R.G. 32 miles did not repeat .Said hes seen this 3 times this summer with the V&H fuel pac.This time I going with the power com.They gar. fix or my money back.We'll see.
Old Jul 16, 2009 | 09:34 PM
oricko's Avatar
oricko
What is TBW
Old Jul 16, 2009 | 11:51 PM
ftanner's Avatar
ftanner
I hate to differ with those who indicate my first issue was not a TWB issue... IT WAS and verified by HD. They indicated that the software program written for the first 08 Models had a programing error and needed to be corrected... The previous software program was allowing riders to reset the nominal idle condition during shut down...if they moved the throttle. Issue corrected with a new software update.
You just proved yourself wrong...
The TBW is not programmable. The ECU is. The TBW is just an induction module. The ECU is a computer.
Therefore it was an ECU issue not a TBW issue.
Old Jul 16, 2009 | 11:53 PM
ftanner's Avatar
ftanner
Originally Posted by hawg50
sounds like your good old tbw is subject to failure as well.lol
I never said it wasn't. You guys are the ones that think that the "good old cable" is sooooo much more reliable than the TBW is.
I have bad news for you. The TBW will still work of one section of it breaks. Your "good old cable" won't. The TBW has build in redundancy.
Old Jul 16, 2009 | 11:58 PM
emwolb's Avatar
emwolb
i am very happy with the way the fly by wire works. and the cruise control is seamless, no herky jerky stuff going on at all. smooth.
Old Jul 17, 2009 | 12:02 AM
emwolb's Avatar
emwolb
oricko, tbw is throttle by wire. it's stock on 08 and newer harley touring models. it means that there is a stepper motor on the throttle body, and no more throttle cables. neat system.
Old Jul 17, 2009 | 12:34 AM
Paniolo's Avatar
Paniolo
TBW is Throttle By Wire, also known as Fly By Wire where the Throttle Body is controlled by electronic signals sent from the ECM as opposed to cables. In the "old days" bikes had accel and decel cables running from the throttle grip directly to the carb/throttle body. With TBW when you turn the grip it and sends an electronic signal to the ECM which sends another electronic signal to the Throttle Body.
Some folks prefer NOT to have another level of electronics (TBW) between their grip and the throttle body and prefer throttle by cable. Others realize that like electronic ignition and fuel injection, TBW is the way of the future and embrace it. Some have had problems with TBW and others have been problem free. Some feel TBW provides a "lag" between actuation and application and others are able to tune and adjust it out.
Over on HTT, some riders have reported broken wires INSIDE the insulation in the main harness as a reason for TBW problems. Overall HD seems to be having issues with some bikes. While some MAY be operator error, there is a track record of known TBW issues.
