abs ?
Old Jul 17, 2009 | 08:14 AM
cflchurch's Avatar
cflchurch
Default abs ?
can i remove abs from a bike? dont tell me its stupid or not worth it. I just want to know can you do it and not have to change the wheels to non abs wheels? thanks. I have rode two bikes of friends with abs and hate it , I found an 06 roadking police dirt cheap and want it but may opt to remove the abs this winter. any help thanks
Old Jul 17, 2009 | 08:20 AM
timvan's Avatar
timvan
Dont see why you couldnt with some plumming to regular and removal of the abs unit?? you can pull the fuse also to disable it
Old Jul 17, 2009 | 08:57 AM
cflchurch's Avatar
cflchurch
timvan , thank you I didn't know the fuse trick , thanks again.
Old Jul 20, 2009 | 07:41 AM
fevest's Avatar
fevest
What did the abs do that you didn't like? Unless you are using them it should be un noticeable.
Old Jul 20, 2009 | 08:48 AM
Mike5959's Avatar
Mike5959
I have had a few incidents with the abs that I would like to at least be able to disable it with a switch. On more then one occasion going down a steep hill its kicked in on me due to sand and scared the shiznit out of me. I know that ABS has a lot of useability but there are times it is dangerous imho.
Old Jul 20, 2009 | 10:20 AM
timvan's Avatar
timvan
You should be able to use the Aux switch with some wiring mods to have a on-off switch
Old Jul 20, 2009 | 10:31 AM
skydrifter's Avatar
skydrifter
I did that to my 08 SG I ran the ABS through my Aux switch . I turn it off and on as I see fit. I turn it on if the roads are wet, most of the time I have switched off. I like the option to lock up brakes if I need to .
Old Jul 20, 2009 | 10:49 AM
HogManII's Avatar
HogManII
Wink but, but...
it IS stupid and not worth it---
Old Jul 20, 2009 | 10:53 AM
Mike5959's Avatar
Mike5959
did you just interupt the wiring coming from the ABS fuse with a relay and switch?
Old Jul 20, 2009 | 10:57 AM
pastorralph's Avatar
pastorralph
From: Creektown aka Lower Alabama, but not that low
Rented an 08 with ABS. The first time it kicked in I was coming down a steep gravel road with ruts in the North Georgia mountains. I think that scared me worse than my wreck recently. Still, I like the idea of being able to shut if off if necessary.
