e-gas
Old Jul 17, 2009 | 04:22 PM
roadglide2009's Avatar
roadglide2009
4th Gear
Default e-gas
hi folks!
I think the electronic gas in '09- models is a lot worse than the mechanical type before!
my problem is the stop and go- traffic: when you close the gas completely and you want than to accelerate very smoothly the gas is not very sensitiv and the bike jumps forward! so the problem are the first
4 or 5 degrees, the rest seems to be perfect imo.
what do you think- any help or problem-solving?
have fun!
claudio from switzerland
cvo roadglide in yellow/charcoal with power commander, clearview shield
Old Jul 17, 2009 | 05:11 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
sell it and get a TBC model.
hth,
dave
Old Jul 17, 2009 | 06:02 PM
teamstersteward's Avatar
teamstersteward
What
Old Jul 18, 2009 | 06:46 AM
WildBill2566's Avatar
WildBill2566
It may be just the way its set up. There shouldnt be any difference they just moved the resister from the throttle body to the handlebar, so if anything it should be better. All the cables did was to move the resistor remotely. At least thats how I see it, but I may be wrong.
I know with the SERT or whatever the new version is called I can play around with mine, but I personally dont have any issues with it.
Old Jul 18, 2009 | 08:02 AM
SGLarry's Avatar
SGLarry
You know, I never thought about it like that but makes a lot of sense to me!
Old Jul 18, 2009 | 01:50 PM
BCguy's Avatar
BCguy
I think I understand. The throttle has a little on/off action at slow speed. You twist and nothing happens then it comes on all at once. Mine is a little like that and it does make slow speed maneuvers a little lurchy if you are not very careful with the throttle.
If there is an adjustment/fix for this I'd be very interested as well.
Old Jul 18, 2009 | 04:21 PM
roadglide2009
4th Gear
Default Tbc
TBC.... means what??
Old Jul 18, 2009 | 04:23 PM
roadglide2009
4th Gear
Default e-gas
p.s. BCguy describes the problem in the perfect way!
claudio
Old Jul 18, 2009 | 04:25 PM
oppirs's Avatar
oppirs
I add E-85 to boost my octang rating.... Do you?
Old Jul 18, 2009 | 04:32 PM
1931jamesw's Avatar
1931jamesw
Never heard of electric gas....
