mush up front
Old Jul 19, 2009 | 11:48 AM
ledfan's Avatar
ledfan
6th Gear
Default mush up front
I have a 09 rk with a corbin classic solo seat, my problem I need to solve is the mushy front suspension. I'm looking hard at a one inch drop and hoping this would stiffin up the front end and add the hd low pro rear shocks. what I don't want is to bottom thr front into the fender. anyone else do this, have problems, input. thx
08 sg- 103" II, rineharts
09 rk- 103" II bub7
09 se springer- v&h
Old Jul 19, 2009 | 11:56 AM
Dixiebiker's Avatar
Dixiebiker
I changed to Screamin Eagle Fork oil and it made the ride considerably firmer.
Old Jul 19, 2009 | 12:12 PM
frydaddy96's Avatar
frydaddy96
A friend went with Progressive springs on his SG. It definitely took the mush out of the front. He says it is a lot more stable in corners.
Old Jul 19, 2009 | 12:18 PM
iclick's Avatar
iclick
Originally Posted by ledfan
...I need to solve is the mushy front suspension.
Change to SE Heavy (not the Extra Heavy) fork oil. I did a write-up here on the job, which is much easier than the prescribed method in the service manual. Took me about an hour the first time, but subsequent changes should be quicker. The ride is more controlled, firmer but not harsh, and is an overall big improvement IMO.
I would try the oil change first, then if you aren't satisfied go with some Progressive springs. What I would not do is lower the front-end, as that would reduce travel and likely cause more bottoming that would make the ride harsher, not better-controlled IMO.
cncmike
Mar 9, 2018 11:00 AM
Cheesehead_13
Apr 7, 2015 06:00 PM
Mac10
Mar 28, 2013 01:44 PM
mgmmgm
Apr 20, 2009 08:58 PM
MiniMe
Aug 1, 2006 10:30 AM
