Check out the picture. I can't reset my clock. Just to make sure I re-read the set instruction. When I hit set all I get is what you see in the pic and none of the menu buttons work?
I even tried hitting some of the handlebar controls - nothing!
Any help would be appreciated.
Thanks.
Not sure if it makes a difference - it's an o6 not an 08.
It's a very old 06 if it has that issue. Check your software, may still be running 6.8. If it is, update to 8.19.
If it is running 6.8 be sure you follow the instructions on Harleys site. use good media and burn at a slow rate. Any data corruption on 6.8 units will lock it up.
