Mid-Frame Air Deflectors ( DO THEY REALLY WORK?)
Old Jul 22, 2009 | 08:14 PM
  #31
Jim Dawson's Avatar
Jim Dawson
I looked at them all and decided that the HD shields beat them all in looks and they work fine. The others look too "home made" for me.
Old Jul 22, 2009 | 08:25 PM
  #32
RBWIDE's Avatar
RBWIDE
Originally Posted by Bad Pig
<snip>
one thing i have noticed about this forum is that if you don't have a 08 or newer bike your not given the same respect as those who can drop the moolah on a new bike every year. so look out you 08 owners! the 10s are here!! ha ha
As long as mine keeps running without any problems, I'm just fine with that. If someone doesn't 'respect' me because I don't 'upgrade' the ride year after year, then I guess their 'respect' is worth about what I paid for it.
Old Jul 22, 2009 | 09:21 PM
  #33
woohooyou's Avatar
woohooyou
I tried the HD shields and they seemed to trap the heat when sitting still. It was the about same with the stock exhaust and Rinehart TDs.
I installed a 2-1 exhaust system which eliminated the heat directly under the seat (see pic). I also added an HD oil cooler. With South TX temps being in the 100's for the past month the bike and I can take it.
Attached Thumbnails Mid-Frame Air Deflectors ( DO THEY REALLY WORK?)-dsc04747.jpg
Old Jul 22, 2009 | 09:32 PM
  #34
dh2683's Avatar
dh2683
Kurys will not last I promise you. The HD ones bolt on and have stayed on mine with no problems but they do work.
Old Jul 22, 2009 | 09:39 PM
  #35
Streetrunner's Avatar
Streetrunner
My SG runs at 240 most of the time. I do have RJ's but a friend has HD, they look ok and he claims they work great. Much cheaper than all the others available.
Old Aug 11, 2009 | 10:12 AM
  #36
AndrewMichaelZ's Avatar
AndrewMichaelZ
Bought the HD Deflectors and have installed the left side no problem. I've got an 07' Street Glide that has Bassani True Duals and a Power Curve. Anyone have tips on getting the right side deflector on. The top screw is blocked by the rocker top and the bottom is blocked by the power curve. Do I need to remove the exhaust?
Thanks
Old Aug 11, 2009 | 10:17 AM
  #37
jimsflh's Avatar
jimsflh
Originally Posted by mike5511
something else going on here if you didn't have a heat problem and all you did was change mufflers and now you have a heat problem........where are the top wrenches out there???
May need some tuning to compensate for the new mufflers, not sure on the newer bikes if the power commander or whaat ever does it auto. My carb needs adjusting with exhaust changes.
OldMike
Exhaust System Topics
Feb 28, 2019 08:28 PM
roadking012
May 11, 2013 10:07 PM
jjr
Jul 7, 2009 09:37 PM
RODEO
Mar 6, 2009 09:10 PM
tbone52
Jul 19, 2007 06:38 PM
