Question about oil level
Old Jul 21, 2009 | 11:53 AM
Bluegrasser's Avatar
Bluegrasser
I don't let my crankcase drain long...maybe 10 minutes or so...so I only put in about 3 qts per change. It takes me 3 dots below the top when cold and on the jiffy stand.
I learned the hard way not to put 3.5 in. It took the cold level to the point where it should be if hot so I got blow by and had to do some clean-up and change my air cleaner element.
Old Jul 21, 2009 | 12:03 PM
hubble's Avatar
hubble
I can't put 3.5 qrts in either. If I do it comes out the breather to. Although the manual says 3.5. 3 qrts is good for me..............
Old Jul 21, 2009 | 12:23 PM
Ultrasweet's Avatar
Ultrasweet
Just had mine serviced yesterday. The tech told me he puts in 3.5 qts. This morning I checked it and it was past full. WTF? T.
Old Jul 21, 2009 | 12:29 PM
littlebear's Avatar
littlebear
Road king Ron, Not to steal the thread, but I too start the engine after draining oil, let her run all of 3 seconds, alot of old comes out. Saw this done on my 1000mile service at the dealer by a very good tech. I don't think 3 sec will cause any problem.
Old Jul 21, 2009 | 12:32 PM
garyhendley's Avatar
garyhendley
i would not run a engine even for a second with no oil in it after a couple of changes
it will be all syn and safe to-ride safe
Old Jul 21, 2009 | 12:41 PM
Arizona's Avatar
Arizona
The '09 RK takes 3.5 quarts with filter. I don't have an oil cooler on this bike. If it had an oil cooler I'd expect it would take a bit more - those of you running an oil cooler: what does your bike take on an '09 touring model?
My '05 EGC had an oil cooler took exactly 4 quarts with filter.
Old Jul 21, 2009 | 01:15 PM
Ultrasweet's Avatar
Ultrasweet
My daughter called me one day and asked me what the light on her dash that looked like an oil can was for. She had already driven it 5 miles with it on. To make a long story short, the oil filter had come off and she had driven the car about 10 miles with no oil. She had just had it changed a month before with Castrol semi syn. The 07' Corolla had 35000 on it then it now has 80,000. No noise and problems. I would not have a problem with running the bike for a few seconds without oil though I don't think it would be necessary. T.
Old Jul 21, 2009 | 01:17 PM
iclick's Avatar
iclick
My '07 should be the same as an '09, and it takes 4 oz. over 3.5 qts. to make the fill line. Exactly 3.5 qts. shows 1/6-qt. low. I have the HD Premium cooler installed.
Old Jul 21, 2009 | 02:23 PM
UltraTheo's Avatar
UltraTheo
I have an oil cooler on my '09 and I add 4 quarts at every change.
Old Jul 21, 2009 | 05:04 PM
BlueSoftail's Avatar
BlueSoftail
I do something similar, however, I pull plugs so the motor don’t start and add a fresh quart of oil before I roll it off on the starter prior to putting the oil filter on. It cranks for about 10 seconds before I get clean oil out of the engine.
