Brakes are pulsating
Old Jul 22, 2009 | 08:09 PM
SE120RG's Avatar
SE120RG
Default Brakes are pulsating
25k on my bike and the front brakes are pulsating(sp). Do the rotors need to by turned or just replace the pads.
Old Jul 22, 2009 | 08:27 PM
Dr.Hess's Avatar
Dr.Hess
Neither. Replace the rotors.
Old Jul 22, 2009 | 08:31 PM
dnitram's Avatar
dnitram
Absolutely! What he said!!
Old Jul 22, 2009 | 08:42 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
It sounds like they are slightly warped.
Old Jul 22, 2009 | 08:57 PM
dh2683's Avatar
dh2683
Rotors are warped.You cant turn them but i have straitened mine a couple of times by attaching a homemade pointer indicator to the forks and watching the runout on the rotor by spinning the wheel and very lightly with a rubber mallet tapping the rotor back to true.
Old Jul 23, 2009 | 02:50 AM
emwolb's Avatar
emwolb
did you run into something, or would anyone have intentionally kicked the side of your rotor? just curious. you should be able to find take offs from someone who's gone to the chrome centered ones. with the 07 though, it's pre brembo calipers, so they'd have to come from 07 or earlier.
Old Jul 23, 2009 | 06:37 AM
mainshaft's Avatar
mainshaft
Smells like warped rotors, did you hit the front brakes hard? I hit them hard stopping at a red light and didn't release the lever until the light turned green and they pulsed the rest of the day. Rotors are not cheap but changing them out fixed my problem, good luck.
Old Jul 23, 2009 | 06:52 AM
Notgrownup's Avatar
Notgrownup
Have you added fluid lately or checked it....May have let air in the system???? Just a thought...I did and then bled the system and it went away.
Old Jul 23, 2009 | 07:28 AM
FastHoss's Avatar
FastHoss
No it's rotors,it's a stock Harley thing.Mine has had warped rotors for almost 2 years now,no biggie.If the front brake pads ever start to wear I will replace the whole deal.At 30,000 I replaced the rear pads just because,they were not worn much.
Old Jul 23, 2009 | 07:48 AM
FLHTCU Owner's Avatar
FLHTCU Owner
Definitely warped rotars. Take the opportunity to replace with polished/chromed. Unless something hit them, the only thing I can think of would be they possibly got wet while hot?
