True Track
Old May 25, 2006 | 06:05 PM
BluegrassBuck's Avatar
BluegrassBuck
Default RE: True Track
ORIGINAL: RBJones
Thanks for the replies. Bluegrass, sounds very serious in your case. YOu'd think there would be an aftermarket company that would come up with a better bushing system. Seems like that would be better and cheaper than adding a stabilizer to the bike. It must be a problem that doesn't occur in all bikes because I haven't heard that many complaints.
I don't think most people ride as hard as I do. Try going double the posted speed on a turn. I'm talking about a turn that would be safe on every bike I've owned expect this one. I'm talking about old Jap bikes, bikes I paid less than $1500.00 for. For $18,000.00 I expect perfection!
Old May 25, 2006 | 06:14 PM
axe11's Avatar
axe11
ORIGINAL: BluegrassBuck
Wow that ridestr8 is expensive. My bike's wobble has gotten much worst in the last few weeks. I don't feel it should be necessary to buy aftermarket stuff to correct a safety issue. I do all the routine maintenance stuff myself but this problem is for the dealer and the warranty.
I must say there are several things about Harleys that are very disappointing. These design flaws has been around for many years it should be changed. This wobble and the poor performance of the bat wing should be fixed. If I had known these things before my purchase I would probably riding a Gold Wing or a BMW right now. Cool is one thing but safety is more important. I like to ride, I ride hard, and push my ElectraGlide beyond it's capabilties almost every day.
OK let the flaming begin!
I don't think there is a problem, per se, with the handling of a Harley with the exception of some of the touring line this year that has reported the wobble effect starting somewhere around 70-90mph and usually on a road that is wavy somewhat or uneven along the surface, and in a curve, something that would possibly put a little too much flex in mid-frame. That's what ridestr8 and true-trak designed their braces to address. I've never run into the problem myself with previous Road Kings, and I've never experienced it on Ultras that I've run, like my Dad's 05' Ultra, blessed be his memory, but I know a few that have with their Ultras. I wouldn't throw the baby out with the bath water, though, on a relatively small number of occurences with this problem. It's fixable and is covered under warranty, but you may have to shop around a little for an HD dealer with a worthy wrench--I know of some if you're in Florida. I used to ride Kawasakis and Suzukis before I migrated up to a Harley years ago and, I gotta tell ya dude, I don't think there's a better bike on the road...but I'm biased...pay no attention to the man behind the curtain. So, everybody, enjoy your Harleys like the next best thing since sex.
Ride on,
axe11
Old May 25, 2006 | 06:19 PM
BluegrassBuck
Do get me wrong - I love the Bike - it just doesn't love me back
Old May 25, 2006 | 06:38 PM
axe11's Avatar
axe11
Besides making sure the tire pressure is right and the shocks are fine, and Progressive 440's are choice, I'd like to make a suggestion that I got from a dealer owner I much respect to try installation of an HD air baffle--HD part 58520-79TC. Supposedly, this little fix has solved the problem on some cases. Of course, wheel misalignment or off balance due to a missing weight is another issue to be addressed. By the way, beautiful ride you got there. Take care.
Ride on,
axe11
Old May 25, 2006 | 08:58 PM
RBJones's Avatar
RBJones
ORIGINAL: RBJones
Bluegrass Buck,
Well, I have an old 1967 Triumph TR6R and despite it's age it corners better in switchbacks than the Harley at high speeds, partly due to the excellent engineering that went into the Triumph chassis, it's balance and the lighter weight. Now, the Triumph has a lot of other problems, but handling isn't one of them. But I don't expect my Harley to handle that way, just like I don't expect the Triumph to ride like a cloud at 75. I would never take the Harley into a curve at the speeds the Triumph can handle. Every bike's a compromise, so maybe a bagger isn't the right bike for your style. Have you tried a Buell?
Old May 26, 2006 | 10:52 AM
websterdan's Avatar
websterdan
OH MY, My harley doesn't keep up with my indy car, I'm bashing the company, because I can't do want the bike was intended to do!
The Highest posted SAFE Speed Limit is WHAT.
What he needs is a Ninja with saddle bags.......
Old May 26, 2006 | 03:39 PM
Beemervet's Avatar
Beemervet
Previous posts on the subject:
https://www.hdforums.com/m_120435/tm.htm
Helpful post Webster
Old May 26, 2006 | 04:03 PM
RBJones's Avatar
RBJones
Beemervet,
Thanks for referring to earlier posts. I don't ride at 85 anytime and certainly not going to be cornering at twice the speed limit on a Harley bagger, which ensures eventual death or dismemberment of the most painful kind. The only "wobble" I've ever felt has been caused by the wind hitting the bike at an angle or the damned grooved highways, which is perfectly normal behavior for a two-wheeler. These rear stabilizers sound like yet another one of those 'solutions' to a problem that doesn't exist for most of us. In fact, many of these things can create more problems than they fix, such as the ground clearance issue. If I ever have the problem, I'll install new swing arm bushings.
Old May 26, 2006 | 05:37 PM
Gviertell's Avatar
Gviertell
I started this whole thing with a question about there website. But to add to it I ride 2-up most of the time (about 425 lbs. of riders) and we had a wobble cornering slightly hard and worse when the road had an uneven surface. The true track unit helped this problem a huge amount. But it does reduce the lean angle slightly. The unit "drags" on the edge of the "box" portion just before the footboard brackets start to drag. Not very often a problem. For the most part I am happy with the unit, just wondering what happened to the company.
Old May 30, 2006 | 12:00 PM
BluegrassBuck
ORIGINAL: Gviertell
Sorry for high jacking your thread.
I just put "harley wobble lawsuit" into a Google search. Lots of information out there.
