Primary leaking
Old Jul 25, 2009 | 09:31 PM
Ozoneman's Avatar
Ozoneman
Default Primary leaking
Nearly 30,000 miles on my '06 Ultra and my primary started leaking. Is this a common problem? I have the extended warranty so they will fix it for the $50 deductible. I guess I might as well have them put a chrome inner primary on since the labor will be free. When stuff like this happens it makes it cheaper to have accessories added. I think the labor is about $300 for this job and the inner primary is about $300, so I get this one at half price. I had the hydraulic cam chain tensioners and cams installed during a warranty deal also (stock cam chain tensioners went bad). Makes it much more affordable!
Old Jul 25, 2009 | 09:34 PM
bigskyhd's Avatar
bigskyhd
Not a common problem that I'm aware of. Good idea to go ahead and get the inner done while it's apart. That will look nice. Snap a photo for us.
Old Jul 25, 2009 | 09:37 PM
boogiewithtuck's Avatar
boogiewithtuck
Where exactly is it leaking from?
Old Jul 25, 2009 | 09:47 PM
Ozoneman's Avatar
Ozoneman
To be honest I haven't looked that close since I figure the warranty will take care of it. It looks like it is coming from a seal on the inner. It is only a drop or two when it sits overnight. It drips from a spot directly below the derby cover.
Old Jul 25, 2009 | 09:50 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
The primary is about the most common thing to leak on a Harley
Old Jul 25, 2009 | 09:55 PM
Ozoneman's Avatar
Ozoneman
The dealer wasn't surprised. In fact he said he sees a lot of them leaking.
Old Jul 25, 2009 | 10:32 PM
tslonige's Avatar
tslonige
WOW, it would be my luck that it would be the drain plug below the derby cover and I would just drop the bike off and the dealer would try and charge me storage fees then, LOL . Post pics of the new chrome when its done.
Old Jul 25, 2009 | 10:33 PM
Apex Rider's Avatar
Apex Rider
The Dealer found the Primary leak on mine last Fall.Had 25k miles at the time.
Fixed it under the Extended Warranty while I wait.
Old Jul 26, 2009 | 07:59 AM
aclass's Avatar
aclass
Be sure to check the shifter shaft seal while you have the inner off. Thats probably a more common leak than the primary is and a 5 minute/$5 change.
Old Jul 26, 2009 | 08:39 AM
fxlowboy's Avatar
fxlowboy
Had a leak from the leap seal since it's all open i put a inner chrome
