adjusting drive belt `09 FLTR
Old Jul 27, 2009 | 08:33 AM
lowflyer's Avatar
lowflyer
Default adjusting drive belt `09 FLTR
The axle has eccentric washers making this easy. I just removed both bags and right slip on muffler, loosened axle nut put wrench from tool kit on left nut and tapped it with hammer to get about 3/8`s in. play with about 10 lbs. force. I chose to do this on a saturday morning and the H.D. dealer didn`t have a service manual or tension tool to sell me. So I practiced lifting a gallon jug full of water for the calibrated force on the belt. After riding a hundred miles or so saturday I wanted to double check my work. Sunday morning I put it up on a jack and found the tightest spot again, let it down and took off left saddle bag and left cover. I used some string and a fish scale and applied 10 lbs. force on belt measured 3/8 in. play and I`m confident it`s good to go. Got the fish scale at Wallmart and it reads 8.5 lbs. for a gallon jug of water which is right on the money. Couldn`t find any info on `09 belt adjusting in searches so thought this could help somebady.
Old Jul 27, 2009 | 09:21 AM
dawg's Avatar
dawg
A lot of folks use the "twist" method. Take a hold of the belt and twist it. You should be able to get 1/4-1/2 twist on it.
Old Jul 27, 2009 | 09:30 AM
DPete's Avatar
DPete
Sounds like you did a good job, I guessed at mine pushing what I thought was 10 lbs with my thumb and watching the slot in the belt guard. Kinda half azzed but I don't think it very far off, always did my sportster that way
nightrain116
2014-2024 Touring Models
16
Sep 22, 2017 05:15 PM
HDSAE60
May 12, 2015 10:20 AM
Peppa1
Oct 11, 2011 06:58 PM
Aaron01
Aug 4, 2008 09:48 PM
barkster99
Jul 26, 2007 02:37 PM
