CB Radio Issue
Old Jul 27, 2009 | 02:37 PM
DamnYankee's Avatar
DamnYankee
Default CB Radio Issue
I’ve got a strange problem with my radio, and am attempting to eliminate as many possibilities as possible before taking it to the dealership. The radio sound crystal clear on both transmit and received when sitting still, or moving less than 20mph. Above 20mph, you can hear popping / static while transmitting or receiving. I’ve changed out head sets, and verified the noise is independent from engine RPM. I am now thinking it has to be an antenna problem, or ground issue with the antenna. Any body got any other ideas. The bike is an 09’ Ultra with 1300 miles (the radio has acted this way since day one)
Old Jul 27, 2009 | 11:22 PM
goodbirds's Avatar
goodbirds
Lightbulb
WE had this problem on our 02 Ultra. When we bought the 07 I didn't immediately replace the rider's headset,and the popping came with the new bike as well. I had thought the problem was the under tour pak connector to the wife's headset because I had no problems when she wasn't plugged in. BUT, it was my headset after all, and the fix was to replace the headset. The noise may have been more noticeable when the rpms were up and the alternator was putting more juice into the system.
The fact yours is quiet when the bike isn't running, and just off battery, suggests the need for a line filter on the power connection to the radio. Do you get the same noise on the FM side? If so, its probably in the power connection. If not, there could be an antenna ground issue on the CB.
Hope I've helped and not confused you.
Old Jul 28, 2009 | 07:54 AM
DamnYankee's Avatar
DamnYankee
Thanks for the response. FM, auxilliary, and CD are all clear, only the CB is causing the issue. Sitting still with the engine running, or even moving at speeds less than 20mph, everything is still clear. I'm going to check the antenna and ground connection next, thinking the wind is moving the antenna and creating a bad connection. If all else fails, I'll try a new head set. Thanks again
Old Aug 21, 2009 | 01:22 PM
Noble Jim's Avatar
Noble Jim
Dear Mr. Yankee:
I have the same problem on my 08 Ultra. The CB works ok sitting still, when moving there is a lot of popping in trans or receive. Did you resolve the prob?
Jim
Old Aug 21, 2009 | 03:36 PM
DamnYankee's Avatar
DamnYankee
Originally Posted by Noble Jim
Dear Mr. Yankee:
Jim
Yes I did Jim, it was my buddy's bike. He had put the shorty antennas on his about 8 months ago, and apparently never talked to anyone but me on the CB. We took each bike out seperately and used my base station to test them both. My radio was fine, ans his sounded like hell. He put his old whips back on, and problem solved. Only advise I can give is to try another antenna. Good Luck, and let me know what happens.
Old Aug 23, 2009 | 08:30 AM
peddler's Avatar
peddler
Are these the new HD shorty antennas your buddy had installed and had problems with?
HDBagger93
Sep 2, 2010 06:52 AM
Chicago Spike
Apr 19, 2009 08:38 PM
mhonn2220
Nov 26, 2008 03:20 AM
Casper
May 3, 2008 11:55 PM
al baehr
Oct 16, 2006 07:14 PM
