Big Radius guys--in here
Old Jul 28, 2009 | 11:08 PM
cryan9's Avatar
cryan9
Originally Posted by brettnbama
The only problem is, if I get them, I will HAVE to get stretched bags or chrome wheels and rotors and probably lower the bike.......at least that's what I will lead the wife to believe
Okay yes they are loud, but let me say that the Thunder Monster baffles are a must and I mean a must if you run these pipes. They are less than a hundred bucks shipped and take about 30 minutes to install, very easy. The TM baffles keep them loud but make the tone a lot deeper, which creates more sound carry. It is not a high pitch that will hurt your ears. They are very impressive and if you run this setup with the Big Radius and Thunder Monsters, you will be thanking me later and wondering what took you so long to do it. As far as the sound of the Big Radius, yes with stock baffles, they sound the same on my bike as they did on my buddies Street Bob. I know what you mean about lowering the bike to cover up the ugly rear axle. That is why I lowered the rear with he Progressive 430 11.5" shocks, which are 1.5" shorter. It did the trick. I get complements all the time and with those pipes and baffles I am constantly getting asked if I am running high compression heads and if it has been bored out and if I have upgraded my cams. I say nope, it's just the Big Radius with Thunder Monster baffles.
Old Jul 29, 2009 | 02:12 AM
MCMLXIX's Avatar
MCMLXIX
I am definitely going with the black Big Radius on my Pewter Denim Street Glide...(momentary cash flow problems)... I also have a black SE heavy breather sitting on a shelf waiting to go on. I saw cryan9's suggestion before about the Thunder Monster baffles on another thread... I am a little concerned with losing low end torque with short pipes and I was wondering if monster bafflles will increase the back pressure and help with that as well....
I also had the idea of hanging some additional brake lights under the bags where the exhaust tips would normally be.... From the back (when off) it would kinda look normal...
Old Jul 29, 2009 | 07:38 AM
brettnbama's Avatar
brettnbama
Originally Posted by ga4boats
There was a pretty good Youtube of a RK with these pipes - should be easy to find.
I believe I saw that video too......they sound pretty good
Old Jul 29, 2009 | 07:45 AM
dr's Avatar
dr
I have been kicking around the thought of these pipes since I got my RK, I have seen pics of the pipes, but there is something I haven't seen.....where the pipes aren't. Can someone please post a pic of the rear and left side of your bike with the big radius, preferably on a RK
Not to cause problems but you know I ask almost the same question about a week ago and your reply was "this subject has been talked about do a search" then you started a whole section on about how people should use the search section of the forum. WTF...do a search let of info and pics on these pipes.
Old Jul 29, 2009 | 09:11 AM
Pork-Chop's Avatar
Pork-Chop
Originally Posted by dr
not to cause problems but you know i ask almost the same question about a week ago and your reply was "this subject has been talked about do a search" then you started a whole section on about how people should use the search section of the forum. Wtf...do a search let of info and pics on these pipes.
lmfao
Old Jul 29, 2009 | 09:18 AM
beary's Avatar
beary
I was thinking about Big Radius for a while and while I was talking to a tuner about them, an 09 RG and Ultra pulled up with them on. So I went and talked to them and they have basically the same comments about their performance as we are reading here. But as I was talking to the owners, I noticed pipes on both bikes had bent tips where the contacted the road in steep right turns. If you are one who like to scrap the floor boards in turns, you need to consider that.
Beary
Old Jul 29, 2009 | 09:23 AM
Pork-Chop's Avatar
Pork-Chop
Originally Posted by FunkyNova66
I had a set on my cross bones and I must say I miss the hell out of them. With the baffles they were loud with a nice tone. I pulled the baffles out and geezus christ those sum bitches were loud and the suck back between gears was hellacious! I loved them but my riding buddies all hated them. Only because they wanted the loudest bike but I would always drown them out. LOL. I've seriously contemplated putting V&H big radius pipes on my Road Glide but I have a better plan that will be even nastier. bwhahahaahaaa! I say go for it if you like em.
hmmm can we get a hint?
Old Jul 29, 2009 | 09:27 AM
klemay's Avatar
klemay
I've got them on my 08 FLHX, Black...and love them! Now....how to post a damn pic....
Old Jul 29, 2009 | 10:02 AM
FunkyNova66's Avatar
FunkyNova66
Go here and read:
http://www.*****************/forums/he...otobucket.html
Old Jul 29, 2009 | 10:27 AM
cryan9's Avatar
cryan9
You do get some of the low end back when you put the Monster baffles in. I actually gained HP and TQ with this combination from the stock head pipes and D&D slip ons that I had before. What I really like is when you are at cruising speed on the freeway and twist the throttle hard it will really take off. So the top end is real good. As far as scraping the ground with the tips, this has not happened to me even with the rear end lowered. I have taken some tight turns and they have not touched the pavement yet.
