Loose Drive Belt
Old Jul 30, 2009 | 06:27 PM
Pheebo's Avatar
Pheebo
Unhappy Loose Drive Belt
This is what happens if you let your drive belt get to loose. I am glad I can do the work myself. At $200 for a new belt and who knows what the stealer would charge for labor.
Attached Thumbnails Loose Drive Belt-p7300001-1.jpg   Loose Drive Belt-p7300002.jpg
Old Jul 30, 2009 | 06:41 PM
iclick's Avatar
iclick
What is "too loose"? How was it set using the 10# method?
Old Jul 30, 2009 | 06:49 PM
Pheebo's Avatar
Pheebo
To loose was not as tight as a banjo string. Not sure what the #10 method is.
Old Jul 30, 2009 | 06:59 PM
1flhtk4me's Avatar
1flhtk4me
The 10lb. HD tension tool.
How tight are banjo strings?
Old Jul 30, 2009 | 07:13 PM
Pheebo's Avatar
Pheebo
Smile
Tight enough to make a "twang". Squeal like a pig boy.
Old Jul 31, 2009 | 12:28 PM
swlamedic's Avatar
swlamedic
With ten pounds of downward thrust, useing the top of the belt, it should not move more than 1/2" I believe. You might want to check either the owner's manual, or the service manual. At any rate, I push mine with my hand, and if it feels springy, it's good, if I can puch more than 1/2" to 1" then it is too loose. Same thing I do with my chain inside my primary. I just stick a finger in there and see if I can move it. Although, I would recomend an automatic tensioner for the primary chain. Just for peace of mind.
Old Jul 31, 2009 | 12:58 PM
FastHoss's Avatar
FastHoss
Easy to adjust final and primary,do it when belt or chain is hot,never have turned many times to find loose and tight spots,seen many industrial chains and belts adjusted like that no problems.No problems on my bikes either.
Old Jul 31, 2009 | 01:14 PM
Ridewva's Avatar
Ridewva
Good post. Curious, how many miles on that belt? And did the tension suddenly start loosening, or had it been always adjusted on the loose side?
P51Driver
General Topics/Tech Tips
21
Jul 5, 2018 09:23 AM
seoris
Oct 16, 2010 06:41 PM
Gwjvw
Jul 16, 2009 09:16 AM
timebandit60185
May 18, 2008 08:04 PM
Beemervet
EVO
Aug 8, 2007 07:19 PM
