How to remove a rounded-out bolt?
Old Aug 3, 2009 | 11:13 PM
skim1420's Avatar
skim1420
Default How to remove a rounded-out bolt?
I rounded out one of the torx bolts while trying to install the passenger backrest mounts. I thought I'd solicit any suggestions from the board before paying a mechanic to drill it out, etc. Any ideas?
Thanks -
Old Aug 3, 2009 | 11:15 PM
dawg's Avatar
dawg
Drill it and use an EZ-out
Old Aug 3, 2009 | 11:25 PM
jdreed520's Avatar
jdreed520
you can use a dremil tool and just cut a slot on it and use a impact straight slot to work it out. I have used a dremil then just used a good screwdriver i could tap on to work one out before.
Old Aug 3, 2009 | 11:32 PM
Casper's Avatar
Casper
Sears sells the bolt extraction tools
Old Aug 3, 2009 | 11:35 PM
tlb's Avatar
tlb
get a set of allen wrenches(hex keys) find one you can tap into rounded out hole and see if it will grip good enough to get the bolt out.
Old Aug 4, 2009 | 12:45 AM
cgonzgo's Avatar
cgonzgo
+1 works great!!
Old Aug 4, 2009 | 01:20 AM
txfxstrider's Avatar
txfxstrider
I have used the allen wrench as suggested by tlb and also the Sears bolt extraction tool posted by Casper. Both ways worked.
Old Aug 4, 2009 | 02:59 AM
emwolb's Avatar
emwolb
i have a very small pipe wrench that i've used more than once to remove bolts when there is something left of the shaft above the surface. this little thing is more of a novelty item, but it's a rigid and is like 4 or 5 inches long. it comes in handy sometimes.
Old Aug 4, 2009 | 03:52 AM
418S's Avatar
418S
With a long, thin headed punch place it on the shoulder of the torx and tap it with a hammer. It's the poor man's impact driver.
Old Aug 4, 2009 | 06:31 AM
Peppa1's Avatar
Peppa1
I have done it the Dremel tool way and it seems to work good.
