Quick Question..Left Ignition on last night..dead batt
I don't usually forget these things.. I am a car/bike nut and would be ashamed if a good story wasn't behind this error.. My wife and I are trying for our first child, I was in a hurry.. nuff said..lol
I need to know if someone can quickly point me in the right direction on a StreetGlide to recharge the battery. Left Side, Right Side?? I have a trickle charger I can use but I'm not sure which side I get to the positive battery terminal.
You have to pull the seat, unless your dealer thoughtfully installed a lead for a battery tender. If he did, then it will probably be hanging out the right side of the bike (mine is).
Thanks all.
Marc
Are you trying to access it from the side panel?? Just take off the seat and you'll plainly see the positive and negative. If you're a car/bike nut that actually has ever worked on them, this should be about the easiest thing you'll do. You could have done it in the time it took to post your question.
