Air Shock Pressure
Old Aug 5, 2009 | 06:50 PM
locodude's Avatar
locodude
I use the progressive brand, same as hd only cheaper.
Old Aug 5, 2009 | 07:20 PM
dh2683's Avatar
dh2683
Originally Posted by Rutland
Yes it is what I meant, so that is normal then?
Yep its normal
Old Aug 25, 2009 | 09:21 AM
duck_brad's Avatar
duck_brad
Stage I
what is the recommended shock air pressure for an 05 electra glide ultra classic
Old Aug 25, 2009 | 09:26 AM
glmasters's Avatar
glmasters
Stage I
Default HD pump calibration
I have the HD pump, but it now starts at about 10 when it is not attached or when I first attach. Is there a way to calibrate it so it reads 0 to start?
Old Aug 25, 2009 | 09:48 AM
bdp's Avatar
bdp
I bought the low profile SG shocks (54631-02B) for my Ultra and the papers that came with them list the pressure as follows.
Single rider under 160 0-5 psi
Single rider 160-200 0-10 psi
Single rider over 200 5-10 psi
Two up 180 and 120 to 150 passenger 20-30 psi
Two up 180 and 160 passenger 25-35 psi
Two up and fully loaded bags 40-50 psi
Max Pressure 50 psi
Old Aug 25, 2009 | 11:31 AM
gunner11's Avatar
gunner11
GEt the HD pump, it's one of the best buys you will make, you don't want to blow your shocks with a compressor.
Old Aug 25, 2009 | 03:08 PM
VARDR's Avatar
VARDR
I run about 16lbs of pressure on mine all the time. Works well unless I go over a large bump in the road.
I'm 200, my wife is 110.
Old Aug 25, 2009 | 03:17 PM
1931jamesw's Avatar
1931jamesw
I have an 09 RKC. I weigh about 245lbs. If Im riding solo I like about 17-18 psi in mine. If I have the OL on (another 145lbs) I run 40 psi. If we are both on and the tour pak is on and the saddlebags are full of stuff I run max psi which is 50 psi.
Old Aug 25, 2009 | 08:19 PM
elroy521's Avatar
elroy521
2007 road glide , im 300 lbs of rippling muscle , i was running about 18 lbs wasnt cutting it so went up to 35 and boy its good
Old Aug 25, 2009 | 08:25 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
look in the manual for pressures its different for diff models.
