Passing Lamps
Old Aug 7, 2009 | 10:45 AM
Astro's Avatar
Astro
Default Passing Lamps
I need to replace a burned out passing lamp. The OEM lamp is a 27 watt #881 lamp.
It has an angled plug connector. I have heard someone say that you cannot use a lamp that does not have the angled plug. In another thread someone also said that you could use a Sylavania #880ST lamp for brighter light. The 880ST has a straight connector so we have conflicting info.
I would rather use the 880ST if it will fit but I don't want to spend $20+ a piece on these lamps only to find that they will not fit and since they have been installed can't return them either.
Can anybody clear this up??
Don
Old Aug 7, 2009 | 10:55 AM
SA315B's Avatar
SA315B
Are you talking about replacing the bulb or the entire assembly?
Old Aug 7, 2009 | 11:12 AM
Astro's Avatar
Astro
Forgot to say it is an '07 so you replace just the lamp, not the whole assembly.
Old Aug 7, 2009 | 11:15 AM
kemiha's Avatar
kemiha
I recently replaced my passing lights with the Sylvania 880ST. They have the straight plug connector. They will fit, but its tight. Much brighter at night!
Kevin
Old Aug 7, 2009 | 02:48 PM
2006ultra's Avatar
2006ultra
Can I just replace the bulb on my 2006?
Alamomann
Aug 17, 2017 03:16 PM
dandrumheller
May 4, 2017 08:34 PM
BornTexan
Mar 28, 2014 07:05 AM
CT-Bagger
Aug 27, 2011 09:49 PM
Twinrider
Jan 13, 2009 07:32 AM
