NOT Riding Tomorrow
Old Aug 7, 2009 | 08:37 PM
Ogre3239's Avatar
Ogre3239
Default NOT Riding Tomorrow
Just went out to the garage to move my bike (07 RG), and guess what, battery completely DEAD. I was having an issue the other night with the gauge lights flickering and the volt meter would stay at 14volts until idle, than drop to 12volts. So I will be spending the day tomorrow in the garage instead of riding. I guess after 29K miles something had to give. Hope its not to bad.
Old Aug 8, 2009 | 12:19 AM
emwolb's Avatar
emwolb
did you immediately put the charger on your bike? it may be something with the battery connections also.
Old Aug 8, 2009 | 07:58 AM
Ogre3239's Avatar
Ogre3239
I put it on when I found it dead. Checked all wire connections and everything is tight. I will have the battery load tested this morning and go from there.
Old Aug 8, 2009 | 10:51 AM
DrPlastic's Avatar
DrPlastic
Check all your ground connections too
Old Aug 8, 2009 | 01:55 PM
Ogre3239's Avatar
Ogre3239
I checked the system using the format giving here on the site. Battery was good, charged and checked at Advanced Auto. Hooked up the battery, started it and voltage was 14.4 volts (so far so good). Ran the engine to 3100 RPM's and voltage dropped to 4.0 volts. Made contact with a mechanic friend and he told me that he has been seeing issues with the magnets in the stater moving and losing contact (I think that how he put it). at idle it will charge, but not at higher RPM's. I took the bike to him because this is beyond my level of repair. He is going to double check the system. If this is the problem I am looking at $200 for parts. Will see what the final bill will be when done. Will post more later with updates.
Pantera99
Mar 3, 2019 04:57 PM
sammer4u
Electrical/Lighting/Alarm
Jul 31, 2018 08:19 AM
dinolo24
Nov 14, 2014 09:53 AM
scorchedearthpolicy
Feb 11, 2014 12:09 PM
grasman
May 24, 2007 01:53 AM
