new pipes
Old May 30, 2006 | 01:25 PM
howieheels's Avatar
howieheels
Default new pipes
Got the new set-up. V/H slip ons, SE air kit, and V/H fuel pack. Sounds great but do not notice any more performance. Am I suppose to or does this set-up only get me the better sound? thanks
Old May 30, 2006 | 01:40 PM
bountyhunter's Avatar
bountyhunter
Default RE: new pipes
If tuned properly you should get a very NOTICEABLE performance increase, HP/TQ, along with the sweet sound!
Old May 30, 2006 | 02:22 PM
PhilM's Avatar
PhilM
Agree 100% with what Bountyhunter said.....
Old May 30, 2006 | 02:34 PM
howieheels's Avatar
howieheels
How do they tune it properly if they programed the numbers in the fuel pack that came with the instructions? Is there another step they left out that I'm not aware of?
Old May 30, 2006 | 02:44 PM
bountyhunter
Get a PCIII installed and get it tuned on a dyno by an experienced pro. You will get the best performance/fuel economy, worth the extra investment!
Old May 30, 2006 | 03:07 PM
Kahuna's Avatar
Kahuna
I'm not sure what all the functions the fuel pack does. But, you need to have your bike dyno tuned--both fue/air mixture, and timing. These two factors, when tuned correctly, will let your engine perform at its best!
I've seen people who went the less-expensive way, and only did the fuel. The end results were that the performance didn't increase. As you may have seen (on this forum) that most contributors have either the SE Race Tuner or the PCIII. These two modules have proven their performance and have pretty good reputation.
A good dyno tuned by a knowledgeable tuner should improve your performance. Good luck!
ORIGINAL: howieheels
Old May 30, 2006 | 03:32 PM
Primo's Avatar
Primo
The fuelpak optimizes fuel delivery but in and of itself is not further tuneable pass the limits of the factory settings and cannot be improved via dyno tuning.
As said above another unit such as the PCIII or SERT is required in order to dyno tune.
Old May 30, 2006 | 06:57 PM
howieheels's Avatar
howieheels
thanks bountyhunter! I called local bike shop (redline) and they agree that the fuel pack is crap. They want $389 for the pc111 and $300 for the custom map to include the dyno/install. Is $689 plus tax sound good for all this?
thanks
Old May 30, 2006 | 07:02 PM
bountyhunter
Looks like a fair price, everybody has to make a livin'!
Old May 31, 2006 | 01:07 AM
Primo's Avatar
Primo
thanks
Try M & M Cycles .
They have the PCIII for about $100 less.
Here in So Cal the average is about $200 for the dyno with install.
Primo
