Cam Change
Old Aug 11, 2009 | 08:46 AM
hittman's Avatar
hittman
Default Cam Change
I have a 2007 FLHX with 11K on her. When changing cams should I pull oil pump out and replace the yellow o-ring attached, or would it be best not to disturb the oil pump at all.
Old Aug 11, 2009 | 09:18 AM
dawg's Avatar
dawg
If you don't pull the pump, then there is no need to replace the o-ring in the rear. When I changed mine out I didn't disturb it and didn't replace it. Do replace the oil passage o-rings though.
Old Aug 11, 2009 | 09:28 AM
iclick's Avatar
iclick
+1 on Dawg's reply.
Old Aug 11, 2009 | 09:29 AM
masterblaster's Avatar
masterblaster
You might want to check pump alignment, read a few posts here that pump alignment was causing the oil through the filter scenario.
Old Aug 11, 2009 | 02:03 PM
genedjr's Avatar
genedjr
In general the o-ring is very tough and not easily damaged. I would be more worried about the pump not staying in alignment.
...gene
Old Aug 11, 2009 | 04:37 PM
hittman's Avatar
hittman
Thanks guys.
Old Aug 11, 2009 | 04:57 PM
dawg's Avatar
dawg
Anytime you reassemble you should do the pump alignment. As for just the o-ring, don't worry about it if you aren't pulling the pump.
Kevin Rose
2014-2024 Touring Models
25
Aug 11, 2018 07:53 PM
markwolula
Engine Mechanical Topics
13
Sep 6, 2016 09:20 PM
BenRK05
Mar 13, 2014 06:06 PM
hdfatboy54
Exhaust System Topics
28
Nov 25, 2007 07:25 PM
77Tulsa
Jul 10, 2007 04:18 PM
