Touring Fork Plugs
Old Aug 12, 2009 | 09:41 AM
1999E-Glide's Avatar
1999E-Glide
Default Touring Fork Plugs
I am wanting to remove the air lines on my front forks on my Electra Glide,
Fill them with Heavy Duty Fluid, and be done with the air suspension on my bike. Does any one have a part number or directions on what size plug/cap I would need to replace the air-line fitting? My bike is a 1999 Electraglide. Thanks Again.
Kevin
Old Aug 12, 2009 | 09:44 AM
jamesw's Avatar
jamesw
Why?
It's your bike, so of course you do whatever you like, but why not just put in the heavier oil, and retain the air capability to stiffen it up even more when you want to?
What do you gain by removing the air system?
Old Aug 12, 2009 | 06:42 PM
BadPiggy's Avatar
BadPiggy
Kevin
Kevin,
Jamie's bike had the same setup and we removed it.
Take a fork cap to a hardware store and just get a set screw for it.
It'll be metric, I don't recall the size.
Be sure the use some teflon tape on the threads.
Old Aug 12, 2009 | 06:53 PM
xxxflhrci's Avatar
xxxflhrci
Simply change the fork oil and add no air. Leave the air system in place. It works great for quick fork oil changes.
Old Aug 12, 2009 | 07:54 PM
cuda67bnl's Avatar
cuda67bnl
When you remove the banjo bolt for the air fitting, just take it to the hardware store and match it. Put an o-ring on it for good measure. Then send me one of the banjo bolts so I can hook mine back up. If you decide to keep the air hooked up, make damn sure you don't over tighten the banjo bolt. Ask me how I know......
cincypiper
EVO
26
Apr 20, 2020 07:02 AM
flhchaz
EVO
22
May 13, 2018 03:33 PM
Lowrydr2
Nov 9, 2015 03:25 PM
Crashone
Aug 30, 2014 08:43 PM
TexasBowhunter
11
Feb 20, 2012 07:23 AM
