Ceramic coating on exhaust systems
Old Aug 12, 2009 | 11:37 AM
RTBrandy's Avatar
RTBrandy
Default Ceramic coating on exhaust systems
Has anyone coated their StreetGlide?
I'm getting it done and I think I can get away with coating hte shields and the slip-on's, and not doing the headers...or am I wrong in that assumption.... It looks like the heat shields pretty much obscure the pipes completely..
any input is appreciated.
thanks
Old Aug 12, 2009 | 12:27 PM
rocknrod's Avatar
rocknrod
If I were going to attempt to get full benifit of ceramic coating, I would do the head-pipes.
What color are you going to get?
http://www.jet-hot.com/headercoatings.html
The first time I ever had a set of headers coated on a hot rod, I went with jet hot.
Latter on another rod I went with someone else (cheaper) big mistake.
Then I had some other stuff on another rod coated by someone else. Big Mistake.
I finally learned.
Jet Hot for me.
Old Aug 12, 2009 | 12:58 PM
RTBrandy's Avatar
RTBrandy
Good to know...I'm going to see the guy in the morning, but he's got a flat black for the hi temp stuff....
I didn't even know enough to ask more than that
Old Aug 12, 2009 | 01:06 PM
FunkyNova66's Avatar
FunkyNova66
I've thought about having mine done as well. I wanted to drill the shields with large holes then have them jet hot in Sterling silver. Then I want to jet hot the stock pipes and Rinehart slip on in a flat black. I also planned to have the engine and tranny components done in flat black and sterling silver combo.
Old Aug 12, 2009 | 01:55 PM
oinker02's Avatar
oinker02
If you are doing it for looks, just do the shields. If you are doing it for performance and life, then do the head pipes.
If you are doing it for all the above, then do it all.
Old Aug 12, 2009 | 02:11 PM
SA315B's Avatar
SA315B
I have V&H Big Shot Duals with ceramic coated heat shields on my 08 SG. Looks great but I do not believe it reduced the heat over the stock setup.
Old Aug 12, 2009 | 02:23 PM
max56's Avatar
max56
Veteran: Coast Guard
My Fatcat pipe was originally chrome. I had Jet-Hot ceramic coat it black. I wasn't real impressed with the finish. There are a lot of imperfections that I really didn't expect. If I were to do it all over again...I wouldn't. I've never taken temps of the pipe but I didn't notice a drastic reduction in heat, either. When I emailed the company about the poor finish, they didn't respond.
Old Aug 12, 2009 | 04:29 PM
Dr.Hess's Avatar
Dr.Hess
I coated the Sportster's drag pipes with a gun coating from www.lauerweaponry.com, Duracoat. The High Temp stuff. The pipes were looking pretty sad after 20 years, and I sanded them, cleaned them and painted them. My finish didn't turn out as good as I wanted because my coating was 2 years old (got side tracked between the Megasquirt conversion and finally getting to it), but it held up well on the trip to Sturgis. I should have thinned it before shooting, but next time I'll know. Actually, next time I'll read the directions when I get it, not 2 years later and notice that the shelf life is 18 months. Anyway, the coating actually gets harder the hotter it gets and is used on machinegun barrels, which can glow in the dark. Requires no baking, just spray it on and let it dry. It isn't cheap, though.
Old Aug 12, 2009 | 04:41 PM
oinker02's Avatar
oinker02
Heat wrap has no shelf life and actually has become stylish.......be prepared to rejet or remap tho
Old Aug 12, 2009 | 06:51 PM
Dr.Hess's Avatar
Dr.Hess
Speaking of which, anyone have about 3-4" of heat wrap they can sell me? I need to wrap my clutch cable down by the cylinder.
