P1353 = front cylinder no combustion. Check the plug wire to make sure it is tight on the plug. I usually get oxy sensor high codes after I run a long trip steady on the interstate. I usually just clear them and they don't come back until I take a long trip again.
That's basically what I did. I cleared all the codes and check plugs for tightness and took a ride. came back and checked codes. They were none and the engine light has not come back on.
