sert or what???
Old Aug 20, 2009 | 07:50 PM
Shadowryder55's Avatar
Shadowryder55
Cool sert or what???
Have a FLHTCI just got done putting Bubs true dual / w Vance & Hines classic slip-ons also have a HD stage 1 intake. am up in the air about SERT or power commander or even V&H fuel module. Any suggestions???
Old Aug 20, 2009 | 07:58 PM
S&RSGLIDE07's Avatar
S&RSGLIDE07
I have a PCIII. I just had a post named EFI tuner. I was trying to decide to get a dyno tune or try out a Thundermax. I also have a FuelMoto map installed. I was just trying to see if I could get just that much better. After reading everybodys advise I would definatly call Jamie at FM and get a Power commander from him. That way whatever you do with any changes you always can get a map from him. To me it looks like thay are all the same. It is the tuner that makes them different.
Old Aug 20, 2009 | 08:21 PM
davewear's Avatar
davewear
maps from fuel moto are good, same as the downloads from the pc site. i only got 3 more ft/lbs and 4 more tq with a dyno tune.
Old Aug 20, 2009 | 08:24 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
yea there all good the problem is the guy using the equpment fuel moto makes maps that are so close youll useally be better off than a dynotune with a average operator at the controls.
Old Aug 20, 2009 | 09:14 PM
producer's Avatar
producer
PC will work. SERT will fine tune it. Pre packaged maps work just fine. But if you have a mind that won't stop ticking, get a SERT and learn it. It's a lot of fun. I tuned my bike pretty close without a dyno. The biggest problem with tuning is getting the spark advance tables correct. Anyone can throw gasoline at a motor and make power. Unfortunately for them, they don't get good gas mileage. The SERT is a very powerful tool.
Old Aug 21, 2009 | 07:57 AM
FIREHAWK116's Avatar
FIREHAWK116
Why couldn't it be "fine tuned" with a pc? Will the sert do something the pc won't?
Old Aug 21, 2009 | 08:15 AM
hoosierhog88's Avatar
hoosierhog88
Opinions abound about this subject, but here is mine.
I went with a SERT simply because I didn't want a "third party" box hanging on my bike, fooling the ECM and being a possible single point of failure. I have several riding buds that have PCIII and about half of them have had problems with failures. I also know people that have them, never had a problem and swear by them.
That said, I researched the crap out of it and decided on the SERT. I'm 100% satisfied.
Old Aug 21, 2009 | 08:17 AM
Bikerdad61's Avatar
Bikerdad61
According my local H-D shop tuner, the SERT has a lot more parameters that can be adjusted. However, everytime you change engine or exhaust components, it's back to the Dyno and $300.00 for a retune. I'm going with the PCV from Fuel Moto.
Old Aug 21, 2009 | 10:38 AM
Shadowryder55
Cool Help, no sert for 01' FLHTCI what's next!!!
ok, so I decided to go with the sert for my 01' FLHTCI when it comes to find out that Screaming Eagle does not make a race tuner for the 01' FLHTCI!!! what other alternative do I have other than a third party command module??? suggestions PLEASE!!!
Old Aug 21, 2009 | 10:47 AM
Bikerdad61's Avatar
Bikerdad61
ThunderMax with auto tune replaces your stock ECU. You would have to check with them and see if they make it for your '01 Model year.
