center stand question?
Old Aug 25, 2009 | 08:19 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
got mine up on 1/2 inch and still made some contact with the ground then tryed 3/4 took it in the air but i needed a push to get it up couldnt do it by myself.
Old Aug 25, 2009 | 08:36 PM
crackercap's Avatar
crackercap
I have a center stand on my 04 classic and there is no way you could remove a rear tire there is not enough height for the tire to clear the fender, you have to raise the bike pretty high to do this
Old Aug 25, 2009 | 08:39 PM
limj23's Avatar
limj23
Originally Posted by LookMaNoHands
The reason I'm looking: I pull a trailer and burn through rear tires like you wouldn't believe. I can add a set of tire irons to the compressor in the tool kit and swap tires on the road, but without a way to pull the wheel I'm stuck getting bent over by the $teeler...
funny I totally understand and thought this thru myself cause I run spokes/tubes. what about in a pinch back your bike on the sidewalk off the curb (find something thats equal height to support your rear wheel temporarily) then put the bike on the center stand and now the rear wheel is hangin off the curb and you have 6 inches plus the lift the center stand gives you. Or you could carry a compact sissor jack and your all good (there a little pricey though)
Old Aug 26, 2009 | 01:50 PM
dstockton's Avatar
dstockton
After changing many rear tires on my Ultras through the years, you gotta get that sucker about 2ft in the air, that's the bottom of the tire folks, to get enough clearance to wrestle the tire outta there. That aint gonna happen with a centerstand unless it comes with a crane. Unless you remove the rear fender, which is a pretty good job on these bikes, you really need a good cycle jack to safely get it that high. As soon as you pull the axle, the bikes center of gravity changes and it tries to nose dive off of the stand so it's best to have it strapped down pretty good.
Old Aug 26, 2009 | 02:58 PM
FLHTCU Owner's Avatar
FLHTCU Owner
I wouldn't trust it. One good yank and down she goes ....
Old Aug 27, 2009 | 11:15 AM
LookMaNoHands's Avatar
LookMaNoHands
Eh, it's gone over before and it'll probably go over again before I'm done with it ;-)
Old Aug 27, 2009 | 11:16 AM
LookMaNoHands
I was going to try out the sidewalk trick when a guy on another forum suggested a fold up stand that's supposed to do the trick... Waiting for the info from him now.
Old Aug 27, 2009 | 11:49 AM
Geoff's Avatar
Geoff
Neither the Wheeldock nor the Rivco stand provide enough lift to remove a rear wheel.
I checked out both stands and liked the Rivco much better. It has better construction, looks better on a touring bike, and lifts the rear wheel off the ground without a piece of wood.
SluggoMagoo
Apr 28, 2018 11:52 AM
brihvac
Jun 9, 2013 06:30 PM
WoodyHD
Nov 2, 2010 10:58 PM
Geoff
Jan 2, 2009 11:18 AM
4merRacer
Aug 10, 2006 08:39 AM
