Need Help Installing PC-V
Old Aug 29, 2009 | 08:56 AM
1sweetglide08's Avatar
1sweetglide08
Thanks for the pictures...I will try again tomorrow.
Old Aug 29, 2009 | 09:02 AM
Recon's Avatar
Recon
Originally Posted by 1sweetglide08
Yes..there were directions....but nothing about cutting the ecm plate. With ABS there's no room. If anyone has pictures of a PC-V and pictures of the ecm plate cut...would be VERY helpful.
Mine lays right on top of the battery assembly, one loop of the wireing is poked down in front. The sg seat has a resess under it. i have abs and there is little room, but I have had no issues.
Old Aug 29, 2009 | 10:24 AM
izzy's Avatar
izzy
here's the one you're looking for
https://www.hdforums.com/forum/touri...ml#post4722155
Old Aug 29, 2009 | 08:11 PM
pbsdaddy's Avatar
pbsdaddy
I struggled putting mine in my 08 w/ABS. I did finally cut the tray. Sorry, no pics. But, it's not that big an issue. From the air cleaner side, look at the tray. The area that needs trimmed is the upper right, as you are looking at it. I started the cut just inside the corner and removed a piece about 1/2 inch wide and 3 or so inches long. The module will fit in there. It's tight, but it will fit. I think everything else followed the "extra" directions for the ABS bikes.
For those that don't know, the ABS unit is in the right side cover, (where other tourers can put their PC units). With the ABS, there isn't room for much more than a fuse or two.
Old Aug 31, 2009 | 11:42 PM
1sweetglide08
Thanks troy j. I took your ideal and cut a old mouse pad and put it on top of the battery. I put the PC-V and all other connectors on top of battery and secured everything in place. PC-V is running great and keeping my bike cooler. Thanks for everyone's help and advice.
Old Sep 1, 2009 | 07:48 AM
ncbeast's Avatar
ncbeast
crap, I am going to be doing this soon to my 08 RG and would be afraid of removing the tray all together for a piece of foam that could get wet and degrade.
Old Sep 1, 2009 | 08:36 AM
cosshog's Avatar
cosshog
On my 08 glide with ABS I took the battery out and put the first connector in the front part of the frame in front of the battery moved some wires around dropped the bat. back in and secured the pc unit on top of the tray. No problems at all. Sorry can figure that out have no idea how to get pics posted on this site.
Old Sep 1, 2009 | 12:22 PM
ncbeast's Avatar
ncbeast
I have this post saved for when I do mine. It has some good pictures of where to cut.
Thanks
Rickr01
Feb 1, 2012 09:43 AM
DrWalkinboner
Mar 10, 2011 08:03 PM
jcanrun
Jan 25, 2010 09:31 PM
CBNDSDADDY
Jan 16, 2010 11:29 PM
SPARKY01
Mar 26, 2009 07:28 PM
