Nitrogen?
Old Aug 30, 2009 | 12:11 AM
Drail's Avatar
Drail
Default Nitrogen?
Anyone run nitrogen in their tires?
Old Aug 30, 2009 | 12:18 AM
performanceisthekey's Avatar
performanceisthekey
Here you go:
http://blogs.consumerreports.org/car...l<br /> <br />http://www.examiner.com/x-4493-Orlan...it-just-a-scam
Old Aug 30, 2009 | 12:25 AM
xxxflhrci's Avatar
xxxflhrci
I run a custom blend of gases in my tires. It is made up of 78% nitrogen, along with a few other specialty secret ingrediants. It is the best thing for using for those that are concerned with performance, tire life, and bang for your buck.
Old Aug 30, 2009 | 12:27 AM
performanceisthekey
So you running atmosphere in your tires. Good idea
Old Aug 30, 2009 | 12:34 AM
RKKY's Avatar
RKKY
Never bothered running nitrogen. We have it at the shop and some people swear by it. From what I have learned it will keep the pressure up longer. I usually check mine once a week so I'm not too worried.
Old Aug 30, 2009 | 02:07 AM
Clint55's Avatar
Clint55
+1 on that. I run a custom pre-mix of 78% Nitrogen, 21% oxygen and some other trace gases like argon and other crap.
Old Aug 30, 2009 | 03:25 AM
OLD 96's Avatar
OLD 96
Unless ya have a tank of pure N2 in your shop it aint worth it.
Old Aug 30, 2009 | 05:29 AM
russl179's Avatar
russl179
Use helium and you will float away.
Old Aug 30, 2009 | 05:59 AM
emwolb's Avatar
emwolb
okay, so how do they expect to get all the air out of the tire so they can replace it with oxygen. they claim that nitrogen, by having larger molecules will not leak out of the tire near as quickly as regular compressed air. which means that the 78% of nitrogen will remain in your tire, and only oxygen and the other small amounts of various other gasses will leak out? leaving nothing but nitrogen. go figure. they're marketing something like hot air it sounds like to me. besides, a side note, if the nitrogen is not installed by harley, it'll void your warranty.
Old Aug 30, 2009 | 08:05 AM
5point56's Avatar
5point56
+1 On the custom blend. I also filter it through my compressor.
