Check the rear axle nut torque on your new bike . .
Old Sep 1, 2009 | 06:57 AM
coolmac's Avatar
coolmac
Default Check the rear axle nut torque on your new bike . .
I was feeling a little more resistance backing my 2010 RG out the garage
than my 2004 RG. I was thinking could it be the anti lock brakes?
So I checked the rear axle nut torque. It was over 240 ft lbs.
I backed it off and set it at 100 ft lbs.
The bike moves more easy now. This could be the cause of early bearing failing.
Old Sep 1, 2009 | 07:06 AM
1flhtk4me's Avatar
1flhtk4me
You must have one big *** torque wrench!
Old Sep 1, 2009 | 10:21 AM
NiteOwl's Avatar
NiteOwl
wow, thanks for this.
Old Sep 1, 2009 | 11:07 AM
dex0807's Avatar
dex0807
If the wheel has the proper inner spacer how much the nut is torqued shouldn't matter. The only problem would be a stripped axle. I would double check your bearing endplay.
Old Sep 1, 2009 | 05:01 PM
coolmac's Avatar
coolmac
I know the pressure should only be on the bearing races.
All I know, I corrected the axle nut torque and it moves easier.
Old Sep 1, 2009 | 05:55 PM
UltraKla$$ic's Avatar
UltraKla$$ic
I hate it when my nuts are over-torqued!!
djdiver157
Wheels/Tires
Feb 27, 2026 08:56 PM
hdfatbob12
Jan 3, 2024 10:52 PM
GittinThere
Oct 3, 2022 03:53 PM
markaria
Shovelhead
Jun 3, 2015 05:51 AM
Tucker99
May 1, 2014 01:15 PM
