Axle nut torque setting.
Old May 31, 2017 | 11:35 PM
djdiver157's Avatar
djdiver157
Stage II
Default Axle nut torque setting.
It appears to me that using the, "HD Axle Nut Torque Adapter #47925", would add leverage to the torque value when tightening the rear axle nut. The manual shows 95-105 foot pounds using the adapter. What would the torque setting be using a socket directly on the axle nut?
Old Jun 1, 2017 | 12:13 AM
multihdrdr's Avatar
multihdrdr
You asked that 2 days ago and received responses
https://www.hdforums.com/forum/wheel...e-setting.html
Old Jan 21, 2026 | 04:27 AM
BigFuji's Avatar
BigFuji
You will need to calculate and adjust the torque if you use an extension as shown in the other posts. There are calculators on the internet for this. Look up extension torque value calculator. You can also research it on you tube. They explain why this necessary.
Old Jan 21, 2026 | 05:43 AM
GalvTexGuy's Avatar
GalvTexGuy
That thread and this thread are from 2017.
Old Jan 21, 2026 | 05:44 AM
GalvTexGuy's Avatar
GalvTexGuy
This is the answer.
Originally Posted by grbrown
It's exactly the same with a normal socket or that adapter. May seem odd, but when using a torque wrench the force applied to the socket or adapter is a twisting force, leverage is not altered. The torque applied at the square hole in the adapter is the same torque applied by the adapter to the axle nut.
Hope that puts your mind at rest!
Old Feb 27, 2026 | 04:11 PM
Tozco's Avatar
Tozco
Maybe the OP doesn't know that the torque wrench must be applied at an angle of 90° to the adapter in order for a 1:1 torgue reading.
Old Feb 27, 2026 | 08:02 PM
GalvTexGuy's Avatar
GalvTexGuy
The OP hasn’t been here in almost 9 years.
Old Feb 27, 2026 | 08:41 PM
bustert's Avatar
bustert
1/2 thread before stripping
Old Feb 27, 2026 | 08:50 PM
J Cagg's Avatar
J Cagg
That's funny! 😆
Old Feb 27, 2026 | 08:56 PM
gonemad's Avatar
gonemad
Rear axle on new bikes? All the strength my old bones can muster with a breaker bar.
djdiver157
Wheels/Tires
May 30, 2017 03:42 PM
ronnie41653
Jul 10, 2012 07:12 AM
myking
Jan 13, 2009 06:19 PM
LockNut
Apr 18, 2007 12:22 PM
Grendel UK
Oct 31, 2006 11:39 AM
