SE 103" Kit
Old Sep 1, 2009 | 06:16 PM
HOGWYLDPR's Avatar
HOGWYLDPR
Default SE 103" Kit
Thinking of doing the stage II 103" kit in my 08 Road Glide. When I read the SE catalog it states that compression releases are recommended. Are they really necessary for this upgrade? The way I understand it is the big bore and pistons are not that high in compression. Curious what others on here have installed with their 103" kits and whether running compression releases or not. Thanks all. Trying to save a few bucks by not drilling into my heads.
Old Sep 1, 2009 | 06:56 PM
BM83's Avatar
BM83
It is only about 10:1 but the 255 cams build more pressure because of the very low overlap. I have HQ 575 cams in mine and it starts easy without the compression releases open.
Old Sep 1, 2009 | 06:58 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I have the 255s and compression releases. I have yet to need the releases to start my bike.
Old Sep 1, 2009 | 07:04 PM
ryanl's Avatar
ryanl
Thats one of the biggest problems with dealer install SE Kits. Deck height is usually not checked, and heads are not adressed. Most dealer builds dont end up at the advertised compression. Basically you wont know what your compression or CCP is until the build is done and you do a compression test. You will either be nowhere close to needing releases, or wishing like hell you had em. I would go with the CR's, cheaper to do it the first time. Or go with a shop that does more than just ASSemble off the shelf parts.
Old Sep 1, 2009 | 07:20 PM
xmeter's Avatar
xmeter
[QUOTE=ryanl;5521301] Basically you wont know what your compression or CCP is until the build is done and you do a compression test. QUOTE]
Doing a compression test does not tell you what your compression ratio is. There is much more to it than that. Do a search on the net and you will find numerous ratio calculators. Once your engine is together you will not be able to find out your ratio unless you did a bunch of measurements beforehand.
I have the 103 kit with the optional high compression pistons. My ratio is right at 10.5 to 1. I also have compression releases and even with them the OE starter did not have enough ***** to crank it over very well.
I ended up going with a high output starter and larger battery cables. Now It starts the way it should.... other than the OE junk compensator that I am in the process of changing.
A friend of mine is having the same problem with his 103 kit and we are in the process of upgrading his starter now. He also has releases.
Old Sep 1, 2009 | 07:31 PM
monkish's Avatar
monkish
I have the high flow heads in my build and manual compression releases. Ended up with 10.5 to 1 compression. Better safe than sorry. I am sure you would not be saving that much money by not doing them. You can read about my build and see the dyno in my sig link if interested.
Good luck...
Old Sep 1, 2009 | 07:32 PM
EG Ultra Classic's Avatar
EG Ultra Classic
yes, get em especially if you get the 255 cam which makes it pull like a locomotive
Old Sep 1, 2009 | 07:35 PM
xmeter's Avatar
xmeter
Both of the builds that I was referring to have the SE255 cams. They are a great low to mid RPM cam but as stated by BM83, they do have very low overlap.
Old Sep 1, 2009 | 07:36 PM
rambobob's Avatar
rambobob
Smile
I enjoy pushing mine. Its a ritual now. I would miss it if I did not have them now.
Old Sep 1, 2009 | 07:59 PM
ryanl's Avatar
ryanl
Good luck...
Took a look at your dyno, gotta hand it to you. It is definately one of the better SE builds I have seen. Gotta be happy with that TQ line...
