40amp or 48 amp
Old Sep 3, 2009 | 11:43 PM
twistedcherokee's Avatar
twistedcherokee
Default 40amp or 48 amp
Talked to a local Indy shop on my charging system & they suggested the 40 amp Compufire instead of Cycle electronics CE48T. Could save me a couple of hundred $$ but not sure it would work right. Anyone use the 40 amp on a Ultra?
Toby
Old Sep 8, 2009 | 11:09 PM
twistedcherokee
So either no one has seen this & it is to far down the line, or not that many people want or can help me on this.
Toby
Old Sep 9, 2009 | 04:21 AM
Harleypingman's Avatar
Harleypingman
Since 2004, the Electra Glides have had 45 amp charging systems; and that's been increased in the past couple of years. Depending on the age of your bike, you could probably retrofit the HD stuff.
Old Sep 9, 2009 | 04:31 AM
Jerry L's Avatar
Jerry L
Was looking for stator info on another forum and alot of guys recommended the CE unit over the stock HD unit. Didn't know Compufire had a setup for this. What year is the Ultra?
Jerry
Old Sep 9, 2009 | 04:36 AM
JayStronghawk's Avatar
JayStronghawk
From 48 to 40 is giving up almost 20% of your Charging ability .. That just don't sit right with me especially for an Ultra and all it's goodies...
Old Sep 9, 2009 | 10:29 PM
twistedcherokee
It's a 1999. I know what you mean as far as it not sitting right. I am afraid that it might burn out prematurely not having enough amps or running at it's max. I think the CE is the way to go,but may check into a HD set up, I think I read about an upgrade stator, so will check them out.
Toby
ericl
Audio Systems
Sep 9, 2016 06:43 AM
Paul D. Brown
Feb 2, 2014 04:17 PM
D-REY
Audio Systems
Oct 8, 2013 09:27 AM
UltraNutZ
Audio Systems
Jun 19, 2013 07:28 PM
fat bob bob
May 2, 2011 05:09 PM
