Hogtunes Amp Install
Old Sep 4, 2009 | 12:46 AM
bigcletus's Avatar
bigcletus
Default Hogtunes Amp Install
Can someone, from their experiences, tell me if the Hogtunes amp has to be wired under the gas tank to the battery on a RG ?? Can it be connected to some other wiring in the fairing ?? Thanks
Old Sep 4, 2009 | 01:45 AM
suey's Avatar
suey
you need to run it to the battery... any wire in the fairing is too small in diameter/gauge... the small wire will get extremely hot and possibly start a fire because of all the amperage the amp will draw
Old Sep 4, 2009 | 07:19 AM
papifun's Avatar
papifun
https://www.hdforums.com/forum/elect...tallation.html
there are some photos of how i did it on my SG routing wire under tank...
Old Sep 4, 2009 | 08:04 AM
stro1965's Avatar
stro1965
Can't say for sure on a RG, but on my Ultra I ran the wire over the tank (under the console). Much easier, plenty of wire to reach. Whole bunch earier to just pop the console off than lift the tank if you ask me.
Old Sep 7, 2009 | 04:07 PM
flyingace's Avatar
flyingace
Ive run both of my installs (07 and 09) under the tank. I MAY have read on the 09s that there is room to go over the tank and under the console, but not sure.
I did speak to PEZ directly about it, and he assured me that the wiring is designed to take the heat if if you run it over the tank.
I did not unbolt my tank, just tucked it up there as best I could.
Pez is a GREAT guy to call with any questions or concerns you may have. He is reachable almost all the time, and will take the time to help you.
Old Sep 7, 2009 | 04:54 PM
1sweetglide08's Avatar
1sweetglide08
I found it best to run it over the tank and under the console. There's plenty of wire and looks good.
Old Sep 7, 2009 | 05:23 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Ditto to over the tank, under the console.
Old Sep 7, 2009 | 05:27 PM
PAStreetGlide's Avatar
PAStreetGlide
I have an 08 street glide and I ran it under the tank console. Hogtunes is a nice set up. Install it right the first time and you'll enjoy it for a long time.
Old Sep 7, 2009 | 07:44 PM
Silverslider's Avatar
Silverslider
Default amp installation
Ok, I was planning adding the new speakers, amp and tweeter to my 09 SG this fall.
According to the Hog Tune web site;
" The speakers “clip” into the factory grills, and the amp goes on top of the radio inside the fairing. While the stock radio is rated for 20 watts per channel, in this configuration, the Hogtunes amplifier makes 32 watts per channel (minimum) and really enhances bass and clarity while the “signature sound” of the speakers cut through exhaust and wind noise very nicely "
So if the amp mounts on top of the radio inside the fairing why would I want to mount it under the seat and route the wires up the tank?
thanks
Jeff
Old Sep 7, 2009 | 07:53 PM
stro1965's Avatar
stro1965
thanks
Jeff
You don't. The wires that run over/under the tank are power, you're tying into your battery.
