I need a PC usb map worth something
Old Sep 4, 2009 | 04:07 PM
tat2magoo's Avatar
tat2magoo
Default I need a PC usb map worth something
I have a Power commander III usb for my 2008 FLTR Road Glide. I have hooker tuned flow slip on pipes with SE air cleaner and stock ECM. No motor Work. I currently have loaded the map from Power Commander website and to be honest it sucks! The stock ecm w/o PC ran much better. I would like any possible maps / advice that could help I'm trying not to spend 300+ at the dyno at this current time. I would rather spend it on one of the many late bills sitting on the counter:0 Thanks!
Old Sep 5, 2009 | 09:55 PM
roamin' iron's Avatar
roamin' iron
6th Gear
You're at the perfect point in time to ditch that power commander, nothing but problems with the two I've had to send back to dyno jet for replacements.
Try a cobra fueler, inexpensive, no dyno needed, reliable.
Old Sep 5, 2009 | 10:42 PM
2000FiveOh's Avatar
2000FiveOh
It takes a while to figure them out without dyno'ing your bike. Even if you spend the bucks to have it dyno'd there's no guarantee that you'll like how it runs. I took me 10 or 12 maps before I finally got it running right. I would run a map and it run real good down low but have shortfalls in the mid or high's. So, i copied the low end numbers into a zero map. Ran a few other maps and found one that ran good in the mids. Copied those numbers. Did the same for hard running. After a while I peiced together a super running map. No spits, sputters, farts, or decel popping, and pulls super hard. It just takes alot of time to figure things out. Fortunatley, I have way too much time on my hands to dick around with stuff like this.
BTW, I've had mine since 2004 and never had a problem with it.
JeffJA
Mar 30, 2018 02:11 PM
1_sik_glide
Mar 2, 2016 12:13 AM
06SGWA
Apr 5, 2014 07:15 PM
rambler43
May 1, 2009 04:12 PM
sweet street glide
Feb 7, 2008 07:53 PM
