Changing Belt Pulley
If you go to the Andrews 30 tooth front sprocket and the Japanese belt (1 tooth less) the final drive ratio is 2.97. At 65 mph it's 2628 rpm. Better!
I've been checking and the 07 and up sportsters run a 68 tooth rear sprocket and a 1" wide belt just like our 07's and 08's. Our stock is rear is 66 tooth. So if you go with the Andrews 30 tooth front sprocket and change the rear to the 07 Sportster's 68 tooth sprocket you end up with a final ratio of 3.07. At 65 mph it's 2707 rpm. I think that lets us run in 6th gear down the highways. 244 rpm greater then stock. With 75 mph at 3124 rpm. This is were I think these heavy bikes should be geared. The belt center distance would be within a 1/16" of the stock belt center distance, so the stock belt should work.
Now you won't be able to run the IDS, and I'm looking at adding the SE compensator in the primary to offset this.
I have ordered all the parts but won't be getting to it till next month.
That is some impressive research.
Beary
I had my old SERT upgraded to TSS MasterTune and that will take care of the speedometer offset.
I'm planning on increasing the torque of this motor so the SE compensator and heavier clutch spring for that reason.
It looks like November before I can get this done.
Keep in mind, I haven't found anyone that has done this, but researching and then talking to a couple HD mechanics, I felt confident enough to order the parts. I'll ring in after I have it all installed.
On the up side the pulley change gave me a great performance boost and I only did the 31 tooth pulley. The stock belt worked with it.
You'll like it.
1. the flange, where the 7/16" bolts go thru, is .50" thick instead of .90" so shorter bolts are required, or cut down the stock ones.
2. the obvious, 68 teeth instead of 66 teeth.
So the Andrews 30 tooth front pulley and 07 Sportster 68 rear pulley = 98 teeth and the stock belt works, with about a 1/16" difference in center distance. The final drive ratio = 3.07.
This ratio is higher then the EVO Industries 30 tooth primary motor sprocket ratio of 3.15 and lower than the Evo Industires 49 tooth primary clutch sprocket or Andrews 30 tooth front pulley + shorter belt ratio of 2.94 or 2.97.
Now just waiting till I have a chance to tear it down and make the swap.
